Results 1 to 7 of 7
Thread: tri-z 250 problems
    Yoakum Texas
    38
    tri-z 250 problems
    i have a 1985 triz 250 with some mods not exactly sure what all with the motor but has exhaust and what not.. anyways the trike will run sometimes and not other and most of the time when it runs it will bog out on anything past idle.. on ocasion it will hall major ass but surges when toped out in 5th. it almost seems like the fuel pump cant keep up with the demand of the carb.. since it will die out while running but will krank right back up... have cleaned carb changed plug checked reeds idk what else to do ita a great bike... just need to get it going and ideas or help would be greatly appreciated... thnxs
    current trike
    1985 TRI-Z 250
    current SXS
    2009 Yamaha Rhino 700
    gone but not forgoten
    1985 ATC 250R
    1983 ATC 250R
    1982 ATC 250R
    Dec 2007
    Southwestern NY
    517
    If it hasn't already been done, rebuild the fuel pump. Very common problem. fuel pump rebuild kit- part #MK52 from parts unlimited. order 2...they're cheap insurance. Get that done and see what happens then. could be an air leak, jetting, carb, etc.... any build-up of oil around the base gasket or reed gasket? That's a sure sign of an air leak. let us know what you find out.
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
    Sep 2006
    Northwest Indiana
    1,893
    Quote Originally Posted by zmpolaristech View Post
    Yes to the above, and check your float level too. If...... you suspect it it running out of fuel, incorrect float height will cause high speed bog due to lack of fuel. Then re-fire quickly due to engine still pulling vacuum and refilling bowl on decel.
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    I second that. Rebuild the fuel pump-mine did the same thing.
    Yoakum Texas
    38
    thanx guys just brangit home from the barn today hacd to finish up some other projects gona try the fuel pump rebuild first will let yall know what happens... this sucker is sweet when runnin right cant wait to get it going again,,,,
    current trike
    1985 TRI-Z 250
    current SXS
    1985 ATC 250R
    1983 ATC 250R
    1982 ATC 250R
    Yoakum Texas
    38
    i ordered the rebuild kit turns out the part number is to a snow mobile fuel pump right... which im sure is the same thing as the tri-z fuel pump.. anyways its on order soon as i get it in gona clean the carb rebuild the pump and mix some new fuel and see how she runs then
    current trike
    1985 TRI-Z 250
    current SXS
    1985 ATC 250R
    1983 ATC 250R
    1982 ATC 250R
    Yoakum Texas
    38
    welp the fuel is pumping now but the tri-z runs horrible has no power and dies out after about 30ft of driving... idk what now????
    current trike
    1985 TRI-Z 250
    current SXS
    1985 ATC 250R
    1983 ATC 250R
    1982 ATC 250R
