Results 1 to 10 of 10
Thread: Want to add ATC tires/rims to a garden trailer for pulilng behind my trikes
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    I have an old garden tractor style trailer that is fairly big. The wheels are missing but the rest of the trailer is there.
    the thing is that the axle is welded to the undercarriage and it used what looked like wheelbarrow tires/rims/bearings on it which are gone.
    I have a pair of Honda 22x10x8 rear tires/wheels that I want to attach to it. What is the best way of attaching them to the trailer? I do have a frozen 85 200m rear axle assembly in my junk pile, should I use that?
    Oct 2009
    brazil indiana
    839
    i will try to post a picture of my trailer later. what i did was to weld 2 350X hubs to lawnmower deck spindles and weld the spindles to the trailer. the wheels fit great.
    Worcester, MA
    1,117
    I planned on just using a junk 200s frame/half of one, with the rear end, and weld that the some other metal for the base of the trailer, meaning it'd use the same tires, same height, and I could theoretically keep the breaks.
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    The carrier on most 185 & 200 unbolt with 4 bolts. Drill two pieces of angle iron that will bolt to this carrier (one on each side) and work from there. I have built several like this. The only drawback to an atc carrier and axle is it is prone to turn over a little more than a trailer with hubs set out wider. I have one built fron a tecate carrier and 4" over axle with aluminum wheels that looks real cool.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Beaver Falls, PA
    2,666
    Quote Originally Posted by Ironbnder View Post
    My plan is the same... a 185/200 carrier is the easiest to work with in my opinion... it's steel, so you can weld on it, and it has bolt holes if you want to go that route. As a bonus, you can run any Honda hubs you want (except 350x and 250es/250sx), the splines are all the same from a 70 to a 200.
    Oct 2009
    brazil indiana
    839
    here are a couple pictures of mine.
    Attached Thumbnails Attached Thumbnails 100_8283.jpg   100_8284.jpg   100_8281.jpg   100_8282.jpg
    spokane, wa
    363
    Okay, I'm taking the rear axle off the 200m carcass frame I have. I got the big 4 bolts out but I can't remove the chain parts or the brake parts because I have no idea how to take the hubs off.
    Western PA
    84
    Quote Originally Posted by jensenracing77 View Post
    I like that, no live axle to drag when turning.
    Ride Red- '86 350X, '85 250ES (Big Green), '83 110
    Sold: '86 200X, '84 200ES, '82 185S
    Feb 2009
    michigan
    2,387
    this is the direction you should go to.i wouldnt use the carrier and axle like you stated
    1985 ATC 250R
    . Team Red Trike
    Oct 2009
    brazil indiana
    839
    lol, i had a fully dressed Oldsmobile 394 engine and transmission on this that was over 1000lbs. even a 442 convertible frame.
