Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: '85 Big Red 250es fouling plugs like mad. No stop
    Feb 2009
    michigan
    2,387
    your too rich for sure.could be syphoning the bowl.float set too high?could be timing also.looks dry black indicates a fuel rich problem.wet black indicates oil in the combustion process.
    1985 ATC 250R
    . Team Red Trike
    Nov 2009
    Okauchee, WI
    555
    It's defanetly a dry black residue. Could tight valve clearances have anything to to with it? Can't budge a rocker at TDC either way.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Feb 2009
    michigan
    2,387
    your moving the motor counterclockwise to the t mark right?rockers should be loose(both).if thats what your doing im at a loss.
    1985 ATC 250R
    . Team Red Trike
    Nov 2009
    Okauchee, WI
    555
    Quote Originally Posted by harryredtrike View Post
    i dont think you should be able to.adjust your valves to spec.
    Not quite sure what that means Harry.
    Just got off the phone with a atvmechanice buddy. I mentioned the type of choke plunger my 250 es has. He said if that plunger and needle isn't all the way seated down when the choke is in the off position it'll let the gas flow in and foul a plug in no time. Gonna check into that right away tomorrow.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Oct 2007
    Minneapolis mn
    4,067
    Fur sure... (heavy on the fur).... If your choke is f-ed up its gonna run rich... Maybe you should email Dirtcrasher.... He is a god of the ES/SX motors....
    Feb 2009
    michigan
    2,387
    Quote Originally Posted by mtsnieg View Post
    i dont even know what that means.i should have read it first
    1985 ATC 250R
    . Team Red Trike
    RTV isn't a good sealer...... Your "O-ring" is conformed to fit, some of those AM kits just give you a crappy arse o-ring.
    I don't own an ES but the SX,EX and 350X all share a similar bowl and the o ring type seal may fit from any of them.
    You could be suking oil thru a bad valve seal or it's rich as heck. Take the airbox lid off after getting a new plug and see how it looks. If it's the same, your getting oil past the rings or thru the intake valve seal.
