CDI Test that worked!200s etc..
Things needed for the test:
Hairdryer and icepack(flexible gel-ice or similar)
This test is if your motor runs, but cuts out or stops running after it warms up.
Take your CDI unit from the rubber holder but leave it attached with the wires.
while your motor is running hold the unit in your hand and point the hairdryer at it (not enough to burn it but get it warm).
If the motor stalls out or starts to run rough..stop the hairdryer and wrap the icepack around it and cool it down and see if the motor runs better.
this worked on my 200 after trying lots of other crap to fix a "runs for about 10min" problem.
Good Luck!
//ArrowChat Integreation Code
