Results 1 to 15 of 29
Thread: ATF in crankcases-did I miss the memo?
    Nov 2005
    New Jersey
    659
    I recently picked up another 250r from a seller in the Midwest, got some time recently to get it running, the usual rebuilding of carbs, bearings etc. TO my disbelief again when I drained the crankcase it was filled with ATF, my Tecate when I purchased that too had ATF in the crankcase, now I know the atf is thinner,but why am I seeing this a lot more then years past, did I miss the service bulletin?
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    Feb 2009
    michigan
    2,387
    some people swear by tranny fluid in the crankcase.it has good properties over motor oil.
    1985 ATC 250R
    . Team Red Trike
    It absorbs water if you ever get any in there, other than that it seems far too thin to be a good gear oil but I'll set it shifts a bit slicker
    EDIT - I remember reading in dirtbike/dirtrider or whatever it was that Ricky Johnson "supposedly" ran vegetable oil in his tranny
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    I've run ATF before, I prefer BelRay Gearsaver 80W tho...
    TF 07,08,09,10,11,12,13,14!
    Nov 2005
    New Jersey
    659
    Stupid question, I can see the properties involving water, it is a friction reducer as well? How can the ATF lubricate the bearings and gears like oil? There properties are not similar.
    TTown, Alabama, United States
    845
    i have run ATF in my trike, and in my car as well. the ATF is a detergent and helps clean carbon deposits and oil sludge. when i got my 185s, it wouldnt shift very good, the lever was sticking and it took a lot of force to put it in gear. i ran a quart of tranny fluid in it for about 4 hours maybe(on and off) and drained it and changed with a fresh quart of Pennzoil synthetic, rode for a few hours then changed it again. i could see chucks of oil sluge coming out of the crankcase. but it really fixed my shifting problem and it takes a longer time to darken up the oil. In a car, mix a quart of ATF with your oil, run for about 500 miles, then drain the tar like substance out of your oil pan. the ATF cleans all the oil passages out. i have yet to see any negative effects from running it in a motor for a short period of time
    Nov 2005
    New Jersey
    659
    Quote Originally Posted by 83ATC185 View Post
    Short time-there is the question of the day-I wonder why it is in there and how long it has been in there-both are/were used when purchased with limited knowledge on there maintenance prior to purchase.
    COLORADO
    685
    ATF wicks heat away very well, but some types (F and H) have slip additives that ruin clutches. I would run Dex/Merc III in a bike to clean it out, then run Rotella T Diesel oil. Always worked for me. for cars, I usually put ATF down the intake if it has been sitting or taking in bad gas, cleans up valves well. ATF in oil for over 500 miles will rape your main and rod bearings, and if its a Chevy 216 Inline, you are screwed anyway, splash lubrication in bottom end.
    In all, run Dex/Merc III for a few laps in anything. ATF works well in manual trannies as well.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    845
    what about mixing ATF with gas and running it in a trike?
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    The clutch disk in a trike is basically the same type disk that are in an automatic transmission. As far as it lubricating bearings and gears, most transfer cases in trucks on the road today run ATF in them also, so I guess it does fine as a lubricant.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Billy Golightly's Avatar
    Billy Golightly is online now Always finding new and exciting ways to not give a hoot in hell Catch me if you can
    Live Oak, FL
    15,070
    I've ran nothing but ATF type FA in the bottom ends of my 2 strokes (several 250Rs, 500R, Tri-Z) for about the past 6-7 years with no problems...the shift better, the engines rev quicker. I like it.
    I would not run it in a 4 stroke engine.
    Silver Creek, NY
    86
    I too run atf type F in all my two strokes. The only issue I've ever had with it is it tends to leak out of worn seals easier than a thicker gear weight oil. I like the feel of the clutch with Type F over gear oil.
    2006 LTR 450-Dasa, PC3, Fuel Intake, much more...
    1991 Blaster-3 Mill Stroker, Flotek Ported, F7, Head Shaved, Flywheel lightened, VF3, 35mm PWK, much more...
    1984 200X-Work in progress
    1985 Tecate-also work in progress
    0GravityMX is offline BANNED, For scamming and circumventing previous bans. First time rider
    Aug 2010
    Cape Coral,FL
    154
    use ATF +4 its much better
    Silver Creek, NY
    86
    Quote Originally Posted by 0GravityMX View Post
    Interesting. What's better about it? Better feel, or just better for the tranny?
    COLORADO
    685
    Better for transmission and clutch. Better on fiber plates.
    Trikes:
    84&85 Tecates
    85 R
    85 X
