Results 1 to 15 of 18
Thread: Gearing for an ATC500 and axle questions
    Aug 2007
    Burlington maine
    652
    First question is, What is everyone running for gearing with their ATC500?
    Second topic is How wide is a stock 85/86 R axle? How much wider do 400EX hubs make this beast? I was thinking of running G force hubs to gain more width. Id like 5-6 inches wider then stock.
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    Jul 2006
    400 ex hubs wont fit, only 250R and 350x the 250R has 25 splined axles and everything else is 24 splined
    Aug 2007
    Burlington maine
    652
    Wow, Thanks. Good to know. I really wish I could run 400 carrier/axle set up. Parts are easier to come buy and endless. Im trying to get a custom swinger made with a 400 rear section.
    Syko, what do you run for gearing? You have just about the only 500 thats not run in the dune as a primary. Mine will have a bit more power then most, But it should close gearing wise.
    2008 Honda 700XX
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    since the 500 has such a high first gear i say you better gear low... i was 13/39 and for tight trails it was too high.. remember the 500 is not a trail bike engine,, also don't be suprised when it will only go 50 mph.. thats the close ratio trans for you.
    Aug 2007
    Burlington maine
    652
    50 huh, Time to scrap the 500 already. Im thinking Ill have the HP to hit 75. Im just looking for a starting point to get it close. Between the 2 ride there is alot of gearing options.
    2008 Honda 700XX
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    I always asumed you would have to gear it tall to overcome the loss in tire diameter going from a dirtbike to an ATV.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Las Vegas, NV.
    2,532
    Quote Originally Posted by Curtis-Tecate3 View Post
    One would assume so, but most people forget that the dirtbike has a huge rear sprocket to go with that big rear wheel.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Honestly unless your doing very tight harescramble type riding you can run whatever gearing you want. I ran 15/36 on my 500R with 18in tires for a long time. Yes, first gear is tall, but its got the low end grunt to pull it. It'll take some experimenting to find something your comfortable with.
    KASEY's Avatar
    4,250
    BUT ONE THING TO REMEMBER ,, I HAVE AN hrc WIDE RATIO TRANSMISSION KIT... thats why i can gear low enough to overcome the first gear ,, and still do 70 topped out..
    Aug 2007
    Burlington maine
    652
    Great, So all the info Im getting is 50MPH and wing it, LOL. I have started buying sprockets, I snagged a new Honda 38T rear for 5 bucks last night. Im goint to run very light sprockets, But his will help me dial in my G spot.
    I was thinking there was a closer gearing area that everyone ran. Like on the Zs, Rappys and other machines I have ran. I was also hoping it would go similar to the bike. I honest was thinking of running the rear tires off my XX. I believe they are 22-9-11s. Im figuring that Ill have enough power to push a 22, And the 9 will push easier.
    Whats this wide ratio kit Im hearing about? My motor gets sent out next weekend for the BBK and I could have one installed then.
    2008 Honda 700XX
    KASEY's Avatar
    4,250
    it took my 2 years to find one... gooood luck.. there is an aftermarket gear set out,,, don't remember who builds it... i think its somewhere in the $1200 range ...
    Aug 2007
    Burlington maine
    652
    I found this and sent them an email.
    http://www.madmanengineering.com/wideratio.htm
    Are the 87-89 tannys for the the TRX the same or close to the ATC?
    2008 Honda 700XX
    Live Oak, FL
    15,070
    No...TRX transmissions are pretty much completely different. The transmission gears in the TRX motor looks like tinker toys compared to the width and size of the 500 ones lol.
    Edit: Mis-read the post.
    KASEY's Avatar
    4,250
    i think he meant trx 250r and atc 250r yes they are the same... they did a slight gear change later... i am not exactly sure what year...
    Aug 2007
    Burlington maine
    652
    Well, Thats a good thing I stumbled apon. Ill let you guys know when I find something out about the 500.
    2008 Honda 700XX
