Results 1 to 15 of 23
Thread: What srew do you use to ride on ice ?
    rayatc84's Avatar
    rayatc84 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    France
    194
    What sort of screw do you use to ride on ice tracks ?
    Last winter, I've used this ice screws with new Innova Power Gear tires on my 86' 250R : Click image for larger version.
Name:	Ice Screw.jpg
    They are 4.5 mm diameter and 10 mm lenght.
    The problem is that after 10-15 minutes, there was almost no scews on the rear wheels; for a 1:30 hour round, it's not great... and it was a 4:00 race on 3 rounds of 1:00 to 1:30.
    So I did most of the race without scew and it's not really fun...
    So have you got better solution than mine to ride on ice ?
    Outside of engines with holes that stink, there is no salvation...
    My feedback thread: here!
    Want to see overseas 3wheelers? http://www.passion-atc.com of course!
    YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    The shop that I hang out at uses sheet metal screws. Can you get hardened sheet metal screws somewhere such as grade 8? I wonder if that would work better if you can get them.
    Sep 2008
    Northwest Indiana
    550
    I use 7/16 or 1/2 inch Gold Diggers, I have lost a few here and there and always check them after a race!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    1/2" Kold Kutters
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    For the lost screw problem, it's more the tire than the screw. What kind of tires were you using?
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    rayatc84's Avatar
    Aug 2010
    France
    194
    Quote Originally Posted by Tecate 50 View Post
    7/16 and 1/2 are the lenght under the head of the screw ? Mine are 10 mm lenght so it's slightly less than 7/16".
    No puncture problem with 1/2" ?
    rayatc84's Avatar
    Aug 2010
    France
    194
    Quote Originally Posted by 250rAL View Post
    It's "Innova Tire Power Gear" 20x10-9; you can see it here : http://www.allopneus.com/INNOVA-POWE...l#performances
    Gum (don't know if it's the correct word !) is relatively flexible, but other racers with more hard gum also lost almost all the screws like me.
    So I think there is also a problem with screws that are too short, but I also fear to flat my tires with longer screws.
    I'm little lost...
    Sabula,IA
    619
    I know some racers use 1 inch(about 2cm) screws that go all the way through then put tire sealant (like Slime) inside to seal around the screws.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    36PJ Keihin
    K&N
    Boyesen reeds
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    London, Ontario, Canada
    1,059
    I used 1" (25mm) Kold Kutters ( http://koldkutter.com/catalog/index.php ) in some 25 year old tires with slime on the inside and haven't had a air leak in two years.
    http://www.slime.com/
    A new stud company I found a while ago......
    http://mf44.ca/en/index.asp
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    rayatc84's Avatar
    Aug 2010
    France
    194
    Quote Originally Posted by RoscoW View Post
    Thanks for the infos and links.
    25 year old tire; so I presume the rubber may be dry and hard.
    Do you mean Slime tire sealant?
    No leak in two years, but no screws ripped?
    Do you fix them with Loctite or equivalent?
    Small precision: it is not to ride on snow, but only on ice track.
    And my ATC have to be ridden during 1:30 continuously without screws verification (4:00 endurance race in 3 rounds, team of 2 riders with 1 ATC).
    In fact I think my current screws are 3/8"; probably a bit short...
    I just found this: http://www.best-grip.com
    Anyone knows or uses it?
    They seems to be very performant and wrenkling, but also very, very expensive : 290€ the box 500 !!!
    Riders who use 1/2" screw: screws do not tear? Do you fix them with Loctite or equivalent? Do you ride long on ice without losing screws?
    rayatc84's Avatar
    Aug 2010
    France
    194
    Nobody to answer my many questions and help a poor ignorant lonesome neo-ice rider ???
    I can't imagine it...
    COLORADO
    685
    I use small sheet metal screws on ice tires. I have seen hoosiers (8 or higher compound) running them.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    I use 1" or 1.25" Kold Kutters and load the tire with slime. They rarely rip out that way.
    TF 07,08,09,10,11,12,13,14!
    rayatc84's Avatar
    Aug 2010
    France
    194
    Quote Originally Posted by Russell 350X View Post
    I just bought 2 rear DUNLOP KT877 20x10-9 and a front KENDA K530F PATHFINDER 23x8-11. I'm going to put 1" srews with Loctite 480 and slime inside tires.
    I have another question: do you put screws on tire before put slime inside, or slime before and screws after ?
    Mar 2003
    3,092
    Quote Originally Posted by rayatc84 View Post
    After you put screws in...then slime...
