Results 1 to 15 of 20
Thread: Looking for advice with buying a 1985 250R?
    Aug 2004
    Port Dover, ON, CAN
    24
    Hi everyone, I am just looking for some advice on buying a 1985 250R. I own a 350X and have never owned a 2 stroke so I just want to make sure I don't miss something and buy a bike that is in bad shape. Here is a couple pics, tell me what you think
    Attached Thumbnails Attached Thumbnails 250Rkingston.jpg   250Rkingston2.jpg   250Rkingston3.jpg
    Feb 2009
    michigan
    2,387
    whats the cost?doesnt look to bad,but has been torn down at least once.top ends wear out,frequency depends on rider and maintenance.should start by second or third kick,and plugs are kinda expensive.look at the rear carrier,people usually beat them up pretty good.dont use a punch and a to adjust chain on the star wheel on the left side.always use a spanner wrench to adjust chain.make sure the carrier is good too.they wear out easy if the bearings go bad and they waited to fix.
    1985 ATC 250R
    . Team Red Trike
    861
    Here is a list of what I can remember I all did on my 86 250 r that really needed nothing but I wanted to plan on 200 mile rides and wanted it reliable. Everything on my 86 was origional. It all seemed good till I got 5 tanks of gas thru it
    oring Chain $60
    sprockets $50
    rear axle carrier bearings (I eneded up putting in a LSR billet carrier cuz mine was cracked) $50 for bearings or $200 billet carrier
    reeds I used vforce $140 Theres cheaper ones
    float needle $35
    ft wheel bearings $25
    fork seals $25
    spark plug cap $4
    rebuilt rear shock $60 (goodwins racing in Zion IL)
    swing arm pivot bearings $55
    Brake pads.$50
    Rebuilt both calipers $45
    clutch cable $13
    air filter $20
    parking brake block off cover Free with carrier
    new stainless braided brake lines front and rear. $60 Well spent item
    new rear rotor $55 yeah I no its a cheap tusk one but it works good
    So this is what I'd all look at my 85 needs pretty much all the same and so would a 3 year old trx 450r its the normal wear out stuff But once it all new it will be along time to have to service it and alot of it has good warranties on it too.
    ]1986 ATC 330R
    Aug 2004
    Port Dover, ON, CAN
    24
    he says he wants 1900 for it, but I asked him and he said he would flex a little. Keep in mind this is in canada, so prices are a little high. what do you think? What I like is that you can see the frame still has the orginal little gussetts in it. And to me this means someone hasn't abused it to the point of cracking the frame and putting in big gussetts to hold it together, but that is just a guess from the picture. I don't quite understand what harryredtrike was saying about "use a punch and a to adjust chain on the star wheel on the left side". Also the 250R didn't have a white frame from factory did they? thanks for all the replys guys!
    Feb 2009
    michigan
    2,387
    number 13 in the diagram.......I don't quite understand what harryredtrike was saying about "use a punch and a to adjust chain on the star wheel on the left side"........i was saying dont do that and to see if previous owners did it
    1985 ATC 250R
    . Team Red Trike
    Iprefer3's Avatar
    Iprefer3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Glendale AZ
    441
    Just my opinion. The bike is not clean enough for the price. Be patient and keep checking around.
    Oct 2009
    monteagle, New Brunswick, Canada
    40
    Around here with new fenders easy to get 3000+ out of it.As long as it runs decent.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    thats not a $1900 trike in my opinion.
    tbo is offline New to the board Arm chair racerNew to the board
    Apr 2010
    grande prairie
    13
    Hard to find good deals here in canada on these. I've seen alot worse than that for that price. I'd beat him down as much as you can and have fun riding it.
    Jul 2002
    El Paso, Texas
    512
    I bought my '85 about 6 years ago. It was entirely original minus a new FMF full exhaust. Pristine condition. Came with a set of paddles, too. Paid $1,600. Just trying to give you a reference here because I don't know the market in Canada. Good luck.
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    harryred: what damage can be done my not using a spanner ? i dont have one so i use the and punch method. and no the frame was not white originally
    Dracut Mass
    307
    I also agree that 1900 is way to high. it does look good but not what id expect to even pay 1500 for. other than the price i see a solid trike with what looks like mostly just cosmetic blemishes
    Thats about an 800$ trike without riding it, it may go down from there..............
    Sep 2007
    oregon
    2,292
    rofl bent frame. $500-$1000.
    861
    In the Wisconsin Area 85-86 250R are all over for 1200-1700. I paid $1500 for each of mine in April and both have all the original plastic except on ehas a mair front fender and both were never kept out side. The post above with the list is what Both of mine realistically need to be dependable. If you are gonna ride on your own land and not drop off some where and venture 100 miles from the truck you dont need to fix everything. Alot of the R's on craigslist have been on there and priced kinda high some for a year now!
    ]1986 ATC 330R
