Results 1 to 3 of 3
Thread: kawasaki klf 220a hates me
    Aug 2009
    salinas
    Unhappy kawasaki klf 220a hates me
    So I got this quad from a friend and it has never ran right since it was new, sometimes if I try real hard, I can have it run for about a day, but after i run it for 30 min, it just gets harder and harder to start, and it stops idling. I think the timing is off on it, because its blowing air out the carburetor and stuff, but I'm sure i fixed that because the cam sprocket was off a tooth from the timing mark, but I'm wondering, how do i check the ignition timing, and how do I make this thing run right.
    heres a list of what its doing:
    backfires every now and then
    trys to run every 5 to 10 sec when i crank it
    gas builds up on the back of the carburetor
    It acts like its starving for gas
    when i sometimes get it running:
    it warms up really quick and starts to over heat after 5 min or so
    it doesn't have much power
    theres a clicking sound when i am driving and let off the gas
    N/A
    5,818
    well i wouldnt ride it more...if you can fix it take it to a shop.
    hey, first set the valve lash. if that's not it, pull the muffler apart, remove the spark arrester. sounds like plugged exhaust.
    one cylinder is not enough!!
