Now I know there are some purists are on this bored so, *dons flamesuit* I thought I had read a while back about someone putting a 200s/m head on a 110 or maybe it was a 125m. (I'm looking to purchase either or right now both roughly the same price) I was looking at different ways to improve performance. However, when I was reading through the brochures it looked like the 200(s/m) had a bore of 60 something whereas the ATC 110 can be bored to 55 and the 125 is 55(ish). How would that play out when doing a head swap? (if it can be done realistically) I'm not worried about it raising compression, in fact I'd also like to know if you can use a different piston to raise compression. Or is milling the head your best bet? Is there a sticky with other tips and tricks?
Thanks,
Nick
