Thread: 84' honda Big Red 200es atc ignition and spark problems
    western ny
    3
    Thanks for the replys,
    I have ohmed out the coil and spark plug wire and and pulse generator they are good, although the 90 degree attached plastic or prestolite spark plug boot does not have any resistance or zero readings, like it has nothing inside I unsrewed it from the wire and checked it and nothing from the digital multimeter. Is there a special resistor inside or is it just shot?
    Also I used my OTC digital multimeter to check the dci module following the chart from the manual, the honda repair manual states that a special digital multimeter must be used or I will get false readings. My OTC digital multimeter has ohms /resistance from 2k thru 20m just like any other, will it suffice for this purpose? By the way out of the 6 pins in the dci module half of them showed bad reading according to the chart. I guess its a bad part unless I have the incorrect digital multimeter.
    If anyone has info to solve this problem please respond.
    Hi, I'm a new 3 wheeler here, can anyone tell me what is causing this condition or have seen this before. I read through pervious posts and not found any similar conditons. I appreciate any help.
    read below.
    This 84 Big red 200es has been in storage for 9 years and in rough condition. I am going through it to see if it going to be salvagable. I shot fresh gas into the cyl and it fired so I cleaned the gas tank out and fueled it up. Two or three pulls and it ran with choke on and idled great throttled up good too. 2 minutes later it quit. Now I have spark only for one pull on the recoil, if i wait 15 seconds it will spark one more time, but continue to pull no spark, changed plug same thing. This is with or without the battery connected.
    Last edited by mektech; 09-09-2010 at 12:20 AM. Reason: new info in problem solution
    0GravityMX is offline BANNED, For scamming and circumventing previous bans. First time rider
    Aug 2010
    Cape Coral,FL
    154
    **read the troubleshooting guide posted in world class help **
    Bristol, New Brunswick, Canada
    43
    Mine had a similar problem when i got it, I thought it was in the pick up coil but it ended up being a wiring issue. The old harness going to the Neutral safety and reverse light were buggered up i got the wiring diagram off of this site and worked my way through it fixed everything i came across and have been problem free since
    ATC 230x bought from aproudcanadian!
    western ny
    3
    western ny
    3
    one spark wonder fix
    The fix is thie CDI module! I bought a new CDI from Honda @$150 bucks plugged it in and all assumptions have ended. The spark is consistent every pull every firing stroke. Now I will go through all electical connections and grounds for continuity replace the spark plug cap boot and clean the carb. Big Red will ride again 10 years after it quit and went into storage.
    Hope this info will help out anybody with the same problems.
    Quote Originally Posted by mektech View Post
    Also I used my OTC digital multimeter to check the CDI module following the chart from the manual, the honda repair manual states that a special digital multimeter must be used or I will get false readings. My OTC digital multimeter has ohms /resistance from 2k thru 20m just like any other, will it suffice for this purpose? By the way out of the 6 pins in the dci module half of them showed bad reading according to the chart. I guess its a bad part unless I have the incorrect digital multimeter.
    read below.
