Page 15 of 23 FirstFirst ... 5 13 14 15 16 17 ... LastLast
Results 211 to 225 of 340
Thread: Aftermarket atc 90/110 frames and other goodies. lets see them
  1. #211
    Jun 2013
    Oceanside, CA.
    618
    Joseph, thanks for the info and pic's, another item to add to the project list to make.
    "HJ"
  2. #212
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    Quote Originally Posted by Joseph Farrow View Post
    Here are a couple of crappy pic's from the original maker. If you look close the high volume workings are thicker than the stock. It also appears a spacer plate is used to accommodate the thicker pump gears.
    Attachment 199014
    Attachment 199015
    Perfect!!! Thank you!!!
    too many bikes to count. too little time on hand.
  3. #213
    Feb 2003
    Australia
    927
    Its an impeller out of a different model Honda with a spacer plate to make up the different in thickness.
  4. #214
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by greenhuman View Post
    Interesting. Can you shed more light on which particular impeller that may be. XR/XL 125???
    * Nicholson 500 Race Bike *
  5. #215
    Feb 2003
    Australia
    927
    I can't remember which model. A trip to a motorcycle wrecker is in order. That's what I did back in the day anyway.
    It's definitely not an aftermarket impeller.
    It reminds me of a lot of re-branded OEM parts etc. I think it was Pro Design who advertised an ezy pull clutch lever. When you flipped it over they had merely re-drilled the hole for the cable end to get slightly better leverage. It was about three times the price of a standard lever but with an extra hole.
    We also had a motorcycle accessory dealer over here selling his own brand of engine case satin black paint. I bought a can and noticed something funny with the label. I peeled it off the can and there was another label underneath it. Taubman's Fiddly Bits the other label read. These blokes were going to the local hardware store, buying off the shelf paint for a couple of bucks, sticking on a new label and getting $12. I had bought a can which they forgot to take off the original label apparently.
    It's all good if you can get away with it I suppose.
  6. #216
    May 2013
    Brownsville, Tn.
    1,271
    Good deal. Thanks for the info. I have tried to run down Bob Oliveira but apparently he has moved and changed his number......
    I will take a stock set and see if I can match it up with some from another model. I have a friend with lots of old Honda motors laying around.
    I remember those Pro Design clutch levers. lol Didn't take but two seconds to see what that was all out.
  7. #217
    Central, Louisiana
    639
    What about this oil pump I just pulled out of a 63 S90? The Y looks factory Honda but the bird is throwing me off?
  8. #218
    Apr 2010
    Australia
    37
    Here's the difference between 90 and 110 rotors.A 125 rotor is 1.5mm taller than a 110.As for something that might be bigger have a look at early xr200xl185 Click image for larger version.
Name:	2014-08-16 20.20.41.jpg
  9. #219
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by WILL_S View Post
    Thanks Will. The 125 impellers look just about right. I'll get a set and play around. Good deal.
  10. #220
    Apr 2010
    Australia
    37
    Atc125m oil pump is a bolt on to the 90/110.
  11. #221
    May 2013
    Brownsville, Tn.
    1,271
    Awesome. That's easy enough.
  12. #222
    May 2013
    Brownsville, Tn.
    1,271
    Back to the "Goodies"
    Polished front hub and axle set up.
  13. #223
    Jul 2013
    mo
    327
    Quote Originally Posted by C.J View Post
    hahahaha i just bought one of these too
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
  14. #224
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    POS hp frame....frame pictured is currently owned by ol deuce
    IMO the odyssey 19 inch tires look best on any 90/110
  15. #225
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by mymint87 View Post
    POS hp frame....frame currently owned by ol deuce
    My Brother is going to use a NOS Odyssey front on his Old School H&S 90/180 Racer.
