2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
66 Honda 305 Scrambler
They should work. The worst you may have to do is make some spacers between the headlight and the mounting ears on the 185s mounts, but the early 185s mount, used a round headlight, so I think they will just bolt up with no problems and no spacers needed. I would make sure and put some rubber washers between the 90 headlight and the 185s mounting ears though for sure.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
Good to know. Thanks
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
I never meant to only post a few pics that no one could get anything from, after posting the first 4 my computer was taking forever to load the rest, then you sorta beat me to the post before I was able to post up more. I'll see what I decide to do with the Bandito 110, most likely get it running and ride it, but until it's done and finished I don't want to let go of any parts. If/when the time comes I'll keep you in mind about the brake pedal. Also, how do I know if this is a late or early model bandito frame, were there significant or slight differences?
Here are the only pics i have of my Bandito framed 90. It has a 85 atc110 motor with the 1970 yellow parts and Cobra exhaust
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
The blue one is a 1980 110 with a factory blue bandito and a ton of other goodies. The right pic is a JSC frame off a U.S. 90 that had a 1980 110 motor in it.![]()
heres one of my mystery framed trikes, its got a 110 with a 125cc big bore kit, web 69 cam, sudco intake,mikuni 24mm carb, chrome forks, cafe handle bars recoil cover polished points and hi low cover 10 in with hoosier rears, its all complete now in pic its 90% done, veal has a few of my old frames listed
ACT NOW THINK LATER!
current trikes owned
minty 86 250sx my rider
pauter flat track framed 110-123cc with custom goodies
pauter mx framed 110-123cc with aftermarket goodies
joker framed 90-108cc with front suspension
2007 artic cat DVX 400
dickson sprint framed 73 green us90 with 110 engine
well its the one in my display picture if the pic i posted above is still not showing up??? has a custom chopper seat and a hurst shifter with b&m aluminum handle the motor seems to sit way low think its a flat track frame????
Swifty, the pic didn't show up. I think the tell tale of a flat track frame is the distance between the center of the rear axle and the seat mount. The closer the center of the rear axle and the seat mount, the more likelihood of a flat track frame. I can't think of the stock 90/110 distance off the top off my head now though.
Nicholson 185s
It looks like I have a late model Bandito frame. Also, the oversized handlebars on mine are some vintage renthal bars with the renthal logo engraved on both sides of the crossbar. Why would anyone put such big bars on something so small?
