Results 1 to 11 of 11
Thread: 70 question .. PLEASE HELP !!!!
    ATC-RYDA's Avatar
    ATC-RYDA is offline At The Back Of The Pack Arm chair racerFirst time rider
    Elmer N.J.
    168
    Well i bought a 70 yesterday brought her home and it ran a little crappy , would only run with the choke on .. So i figured i'd wait till 2day and clean the carb , should do the trick i thought ... Nope ... Got the carb all cleaned out nice tank has no rust but i put in line filters on the lines just to be safe .. Got it running without the choke .. The dam thing runs just fine at an idle even rev's up pretty well while in nuetral .. As soon as u get on and pop it in gear it just doesnt want to go ??? I mean i can drive around the yard all day with it in 1st gear and doing about 2 m.p.h. But it just wont rev up like it should , not even enough to get it into 2nd gear.. And again when its sittin in neutral it'll run fine and rev up to the moon perfectly .. But not with a rider .. I even put my neice who's about 50 pounds on it and it still did the same thing
    please give me some input !! ,, also the pipe has no baffle in it , but i ruled that out when i tried a few different methods of stuffing it with insulation and a few other things to give it some back pressure . Still the same result .. Any info would be greatly appreciated on this one .. Thanks in advance !!
    Heres some pics of her
    MY BABY RIGHT HERE !!! LOL
    86 200x
    86 250r 265cc kit
    86 225dr
    85 250r nice rider
    85 tecate
    85 atc 70
    83 250R bone stock
    88 cr 125
    84 klt 110
    99 yz 125 1st race bike
    02 ktm 125sx 2nd race bike
    Michigan UP
    1,005
    try cleaning or replacing the points, mine was doing the same thing and it was the points. It would sit and idle all day long but would die when put into gear.
    ATC-RYDA's Avatar
    Elmer N.J.
    168
    okay .. well than that is the next thing i will try ,, thank you
    86 200x
    86 250r 265cc kit
    86 225dr
    85 250r nice rider
    85 tecate
    85 atc 70
    83 250R bone stock
    88 cr 125
    84 klt 110
    na
    5,702
    Cleaning the carb rarely works.
    Unless you are meticulous in cleaning the jets.
    The pilot jet is so small it is almost impossible to get cleaned.
    Usually when a stock 70 wont take fuel, it is because the pilot jet is clogged.
    If you put the choke on, does it run better?
    If so, I would get a rebuild kit with new jets and rebuild the carb.
    Points will make them run doggy or hard to start, but in all cases I have had, they usually wont run at all if the points are bad.
    Either way, points are a good suggestion, but I would also just rebuild the carb to. All the parts probably will only cost about 60 bucks including the point kit.
    I have used the Moose carb kits with good results.
    Proudly NOT a member of
    "Team on the Teat"
    ATC-RYDA's Avatar
    Elmer N.J.
    168
    thanks for the input mosh.. well i went to to take a look at the points , pulled the mag off and found the woodruff key to be sheared on the crank so its slightly off on the timing , its just a bummer because the crank where the key slips in is actually wollowed out like maybe the mag was put on loose at one point .. so the key is now stuck in the mag and basically rolled off to one side and the crank is wollowed out to fit ... any way to fix this problem without replacing the crank ?
    86 200x
    86 250r 265cc kit
    86 225dr
    85 250r nice rider
    85 tecate
    85 atc 70
    83 250R bone stock
    88 cr 125
    84 klt 110
    ATC-RYDA's Avatar
    Elmer N.J.
    168
    anybody ????
    86 200x
    86 250r 265cc kit
    86 225dr
    85 250r nice rider
    85 tecate
    85 atc 70
    83 250R bone stock
    88 cr 125
    84 klt 110
    Race Demon is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2009
    coshocton
    245
    Use a new woodriff key with some lock tight, I have got away with it on a stock motor for a while, plus, you know where to look when it starts acking up again, should get you buy till you find another motor, not great but it works in a pinch
    ATC-RYDA's Avatar
    Elmer N.J.
    168
    Well i found a good permanent fix ,, i changed out the bottom end with a good 84 bottom that atc704life had laying around and it worked perfectly .. Set the points to .014 and the thing fires up 1 pull everytime like a dream .. Enjoyed it alot 2day .. Thanks bro !!
    86 200x
    86 250r 265cc kit
    86 225dr
    85 250r nice rider
    85 tecate
    85 atc 70
    83 250R bone stock
    88 cr 125
    84 klt 110
    Nov 2006
    Huffman TX
    891
    Nice little 70 you got there i was going to buy one in failry good shape like yours for 150$, and i called him to tell him when we could arange to pick it up and he sold it out from under me
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Aug 2010
    Geraldton, Ont, Can
    35
    Nice! Glad you got it worked out. I'm looking around for one for my son now. I've got a line on one but it'll be a month before I get a chance to go look at it.(if they still have it...that is) I do have one question though. What's a decent price for a 70?
    '82 Honda Big Red 200ATC
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    After alot of trial and error I can now tell you what caused the key to break off
    The flywheel wasn't torqued properly after it was removed..... I have the same issue with my lt250s. You need to use a spanner wrench and do it right or it will break the key and skip the timing. A lesson it took me years to learn.
