Results 1 to 12 of 12
Thread: Honda 1984 200ES Big Red Transmission
    Sep 2003
    Does the Hi-Lo on the Big Red Shift on the Fly? What type of gear pattern is the transmission(One down, Neutral, four up?), and what are the gear ratios on the thing? Why did Honda only make this type of transmission for one year? I'd like to know as much information on this transmission as possible, thank you in advance for your help.
    Nov 2002
    Kirkville, NY
    3,831
    novacat2005,
    Welcome to the board! The hi-lo on the trikes is switched by a lever near the front sprocket, so no it can not be switched on the fly. The shifting pattern is all up or all down, I think it is down into gear and up is out of gear but I am not sure. As for why it was only made one year, Honda has used the hi-lo trans. on the smaller trikes (90's, 110's, and 125m's) since they started making trikes. The 200es was only made one year, then it was replaced by the 250es. The 200es is a 5 speed transmition with a Hi-lo-reverse sub-transmition. Someone that has a book handy can tell you the gear ratios
    -Andrew
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2003
    Australia
    1,919
    The 200es has a 5 speed gearbox, wit ha hi/low/reverse sub gearbox. It does not shift of the fly. The gears are all up with neutral all the way down. The 200es is a fantastic machine! A real stump puller! The only down side is that it has no rear suspension, hence soft walled tires and low pressure needs to be used.
    If you do get or already own a 200es this machine will not disapoint you!
    Although its not a sport trike! Its a definate famr bike!
    Im in the process of fitting rear suspension on mine!
    Hope this helps!
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Dec 2002
    172
    honda had the dual range trans on the big reds since 82. in 84 they went to shaft drive. also the gear pattern is 5 down, neutral all the way up. the hi-low range was nice but made changing the front sprocket on the 82-83 models a trailprotrailprotrailprotrailprotrailpro. here's a diagram of the 84 sub trans. http://houseofmotorcycles.bikebandit...dept_id=180401
    Mar 2003
    Australia
    1,919
    BUMP...............mine is the exact opposite................any explanations???
    Matt
    Minnesota
    790
    Quote Originally Posted by bigredmatt
    Matt
    What? Neutral IS all the way up and 5 is down matt. I own 2 84's and yeah...
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Mar 2003
    Australia
    1,919
    Yeah, well I have two motors.................the one in the trike now is normal but the parts motor is opposite, also the low range does not work........maybe the previous owner put it together wrong!
    Anyway it dont matter cause the opposite one is the parts motor, so yeah it doenst bother me. :-D
    Matt
    Mar 2022
    Golconda il
    Why does my 200e big red only shift in hi or low range
    2,591
    That's how it's supposed to work. There's no need to go any faster in reverse. That's if you're talking about a 200ES. A 200E doesn't have reverse.
    2,436
    Supreme zombie thread.
    The 200ES has all five speeds while in reverse. Got stuck in first gear? Get unstuck in third reverse.
    Mar 2017
    Antrim county, MI
    53
    While I don't recommend it, the sub trans on a 200es will shift from low range to high while moving. I never tried the other way around though. In my early teens(1993-95ish) I would drag race my friend on his ytm200e. I would run 1-3 in low range, let off the throttle and slip it in high range and finish winding out the gears. I never came close to beating him, but it did accelerate a bit faster that way. It actually slid in nice and smooth without any clunks or grinding.
    Due to age and parts availability I wouldn't try it now, but when you're a teenager out of dads sight and hearing range anything goes lol!
    2,436
    Quote Originally Posted by bobtdms View Post
    For sure. Same here, as I don't recommend it either, but I've done it many times. Not in a performance sense, but just didn't want to stop before changing ranges.
    I'd hold the shift lever up or down until after the range change. That disengages the clutch and further prevents any clunks. It's a little bit of an art, like heel/toe brake/gas/clutch work in a manual shift car while on a steep hill. Got to go James Brown on those pedals.
