Thread: 85 ATC 250sx breather pipe hookup
    1,641
    Where does the end of the breather pipe on a 85 Honda 250sx go after it leaves the motor.
    I think it has a single hookup then it "T'"s" into a double. One goes out the bottom and another up into the frame - This just MEMORY!!
    ANY website with a microfiche ought to show you whats up. It has a thin bracket to hold it all in place, clips bent on the frame............
    Bike Bandit, Service Honda should show whats up or ask for a manual in PDF form, Monroe Mike is super helpful as are many for this in providing links for a manual............
    Starting a new thread looking for a shop manual may help you out.
    EDIT - http://www.servicehonda.com/look-up-parts/03 - #22 is your is part, #23 and #1 are the other tubes.
    Please, learn how to do this yourself....... only benefits you!
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    One end goes right over the airbox passing under the gas tank.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Dc, did you really just advise him to start a thread and ask for a manual?
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    1,641
    I had looked it up.Figure there was a tee due to length of hose that was still on motor.Assumed one end went to the air box but the other line on the tee had me stumped.Haven't worked on one of these in a while.
