Results 1 to 15 of 18
Thread: 200X tires, to tube or not.
    Muskoka, Ontario
    12
    My '84 200X has the right rear tire leaking like a sieve and i am torn on what to do. The tire might accept a tube but it may not. Could i slime the tire or shouldn't I? I don't want to replace the tire but if i do it will be a duro HF 240. If i do replace the one tire will it affect handling?. Any information is appreciated.
    Thanks
    Pacific NW
    4,255
    you can feel free to slime a tube and it won't ruin the tire for a real fix later on , unless its not salvagable.
    tube and ride
    hey wait, why wouldn't it take a tube?
    I pulled a full sized car tube out of a tire one time.
    Sheer genius.
    it was all folded up and tied with string but it worked for a few years for me, I didnt even know it was in there until I changed the tire for some reason.
    ok, now i saw slime in the bike section, little bottle for 7 bucks....ok?
    went over to farm and garden and a bottle twice the size was 1/2 that price.
    Muskoka, Ontario
    12
    thanks, It's possible the tire might be so ripped the tube will shred after a little while though.
    obijuan's Avatar
    obijuan is offline At The Back Of The Pack Arm chair racerFirst time rider
    san antonio texas
    226
    Quote Originally Posted by geargrinder View Post
    thanks, i've tried to tube a tire before but it was so ripped the tube shredded before i got 20 miles. I might try the slime.
    why dont you just fix the tire....
    Crest California
    3,014
    Or get a new set. You don't want that thing tearing on you right in the middle of a ride.
    LED obsessed
    2015 Yamaha FJ-09
    obijuan's Avatar
    san antonio texas
    226
    first, put a picture of the injury. whats wrong with it?
    Feb 2009
    michigan
    2,387
    id get a new set of tires for my ride.your tires sound shot and they will leave you in a mess down the road.
    1985 ATC 250R
    . Team Red Trike
    I too like new 300$ sets and feeling DONE with it!
    I'll Slime a tire but I despise tubes. If the tire spins the tube tears at the base of the air valve. Hence the reason I always ran about 8PSI when I had ton use a tube.
    There areb some great package deals or take off wheels out there for under 200$.
    Tube costs 20$ and 15$ to unmount one side, if it fails and you already 75$ in time, materials and labor into it........ Gotta find what popped it too or bye bye tube.
    They also feel very different IMHO............
    Toronto Canada
    697
    I'll slime a tire if it's a slow leak (1 PSI / day type thing) including rim leaks.
    Otherwise, it's time for new rubber!
    Aug 2004
    Ab Canada
    4,368
    Where is it leaking from? Most problems can be fixed, Im not a fan of tubes, but if Done right..will work in most case's if your tire spins on the rim it ill rip a stem,,,But your tires should not spin on the rim....Slime is ok, but i use some better stuff...For industrial grade tires (tractors, graders, loaders ect) That Works WAYY better. Slime is for Tires with Liner cracks and Seepage issues..most of the time on older ones, but some newer stuff has problems too...
    1985 Tri-Z-
    Crest California
    3,014
    I spent $180 on a set of knobbys as well as having them mounted onto the rims (after they removed the old balloons). Those are on my 200x in my sig/avatar.
    LED obsessed
    2015 Yamaha FJ-09
    Terryville,CT
    1,616
    I say Put some used/newer tires for cheap and call it a day!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Muskoka, Ontario
    12
    thanks for all the advice. it's a slow leak from all around. the sidewalls are cracked, mainly from sitting with a flat tire for about 15 years. i can get the HF 240s for $53 each so i might try those, do i need to replace both rears or just the one that leaks?
    Crest California
    3,014
    Just replace both of the rears and be done with it.
    I should have replaced my front 200x tire as well, but noo
    LED obsessed
    2015 Yamaha FJ-09
    Nov 2009
    N Hollywood/ CA
    588
    geargrinder,
    I have a good set of 21 x 10 x 8 tires, if they fit your bike, there yours. In memory of Ronnie.
    bigworm
