A compression test would be the best way to tell if the rings are worn, if your not going to take the top end off and do a ring-end gap test using feeler guages. If you think it runs good, run it till she blows, then rebuild it! Just keep an eye on jetting - by doing plug chops. If it runs really hot, it is lean, and somthing will have to be addressed (an air leak most likely) Good luck!
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
