gas tank rubber front mounts?
Aanyone know where to get them or how to make some.
Every honda I've seen has different diameters, lengths.
Just had to weld 2 b red tanks because they weren't mounted correctly and fractured the tanks.
Now I glue them to the frame with contact cement, or hide them if I see them trying to get away.
whatever you need can be obtained by using other things.on my 185s i use coolant hose for a totaly different thing cut to size
1985 ATC 250R
Team Red Trike
Thanks,
I was just thinking about stuffing some fat diameter fuel line into some appropriate diameter heater hose.
Yea, welding those fractured tanks was a real exercise in crack chasing.
They really seem to want to be suspended in rubber mounts on all 3 points,
sure is easier to have the right ones but they like to run away and hide long before we rescue the old trikes.
//ArrowChat Integreation Code
