Results 1 to 3 of 3
Thread: gas tank rubber front mounts?
    Pacific NW
    4,255
    Aanyone know where to get them or how to make some.
    Every honda I've seen has different diameters, lengths.
    Just had to weld 2 b red tanks because they weren't mounted correctly and fractured the tanks.
    Now I glue them to the frame with contact cement, or hide them if I see them trying to get away.
    Feb 2009
    michigan
    2,387
    whatever you need can be obtained by using other things.on my 185s i use coolant hose for a totaly different thing cut to size
    1985 ATC 250R
    . Team Red Trike
    Pacific NW
    4,255
    Thanks,
    I was just thinking about stuffing some fat diameter fuel line into some appropriate diameter heater hose.
    Yea, welding those fractured tanks was a real exercise in crack chasing.
    They really seem to want to be suspended in rubber mounts on all 3 points,
    sure is easier to have the right ones but they like to run away and hide long before we rescue the old trikes.
