Thread: PJ1 Carb cleaner
    Apr 2003
    Bay Area CA.
    2,638
    PJ1 Carb cleaner
    Anyone use this stuff? im thinking about getting some to use in all my bikes. Is it worth buying?
    http://www.rockymountainatvmc.com/pr...dFamilyId=3537
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Pacific NW
    4,255
    thanks for asking. Hopefully you'll get opinions like it works, or it melted my whatever.
    We used to call them engine cocktails.
    Makes the owner feel better but you never quite know the outcome.
    I f you can, spotless gas tank, screen and filter, carb, keep the tank full and you can go for years without a problem.
    I usually, well ALways drain my floatbowls if they're gonna sit very long.
    Then again, it could be the best stuff ever made.
    PB blaster gets all the rave but it WILL swell rubber seals as part of a destructive process. for instance. but that can be both good and bad, depending on what effect one is looking for
    Let's hear from people who've used it.
    Apr 2003
    Bay Area CA.
    2,638
    really caught my interest, some of this stuff and fuel stabilizer should really help me out.
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Aug 2007
    Moab, UT
    1,807
    I've used it in the past with snowmobile engines, it works about 60% of the time if the directions are followed. If you are one of those people that thinks more is better, be prepared for a catastrophic piston meltdown, if it's a 2-stroke. The bottom line is, there is no substitute for a good ol' carb teardown and cleaning. The people that swear by Stabil and Seafoam, I'll tell you from first hand experience over the years, it leaves a dusty white film in your floatbowl if left over a month. That film can partially clog jets too.
    Pacific NW
    4,255
    I had my suspicions.
    Thanks for the info.
    I really don't need any more elp making things worse.
