Results 1 to 13 of 13
Thread: need info on older yamaha 3 wheeler
    Sep 2003
    6
    A friend gave me a older yamaha 3 wheeler. I have no info on this 3 wheeler. The only way I know it is yamaha is because is says yamaha on the front mud flap. I see no numbers on it to tell me what year or model. It is yellow I'm guessing it is from the early 80's. I was wondering if anyone could tell me how to find out what year it is, and what model. I need to figure this out so I can order parts for it. Thank you for any help anyone can give.
    Aug 2003
    85
    Welcome, first check the ads section of this site. See if you can match what you have with one of the pics of the Yamaha trikes. Does it have front and/or rear suspention? Does it have shaft or chain drive? Also check on the neck of the frame and see if the model or year is stamped on there. Hope that helps.
    Feb 2003
    Delano, CA
    616
    Do you know if it's a 2 or 4 stroke?
    Does it have front suspension?
    Look on the front steering stem and tell us the first 3 number. (it tells the year and model of it.)
    Does it have gas tank cover.
    Does it look the pic below.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Nov 2002
    1,189
    tire size? chain or shaft drive?? single piece seat and fender or just a seperate fender and seat???
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Apr 2002
    s.w. michigan
    6,498
    info
    i am sure yamaha puts their frame serial numbers on the left side, down by the left footpeg ,,, just in front of it.
    john
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: info
    Quote Originally Posted by jeswinehart
    john
    Only on Golf Carts John. They put them on the steering neck ( behind the headlight on 3 wheelers.
    Howdy
    Sep 2003
    6
    more info
    It looks just like the pic Bigred110 showed. The numbers off of the front frame are 4u3-010203 this same number is on the engine. it is chain drive. pull start. no shocks or suspension. The seat is attached to the big rear cover. gas tank is upfront with a cover over it. there is also some sort of rear tank on the left rear. I don't know what goes in there. I assume this is a 2 cycle. What kind of fuel oil mix shoud I run? This thing has been sitting about ten years, I am trying to get it running. Thanks a lot.
    Feb 2003
    Delano, CA
    616
    It's a 1981 yamaha 125 Tri-moto 2 stroke.
    Mine is a 82 175.
    2004 TRX450R
    Feb 2003
    Delano, CA
    616
    Re: more info
    Quote Originally Posted by toolmaan
    Thats your oil tank. You put 2 stroke oil in it and mixes with the gas. I don't have it on mine so I just mix it. Mixing is also a little safer then using the oil tank.
    32-1 is always a good base line. Get a ratio rite(measuring cup for your mix). You just fill the oil up to the ratio that you want and mix gas.
    2004 TRX450R
    Sep 2003
    6
    more questions
    Well I took the oil tank off plugged the line, pulled the carb and cleaned it out pulled the gas tank cleaned it out added 32:1 oil/gasmix. Now I got it to run and it runs well, but I can't get it to move. I checked the oil in the trans and it looks good,level is ok and is clean. I am assuming this is some kinda of centrifugal clutch?? Anyone know what speed this is a 2 or 3 speed? Do these have clutch problems? I can get it into what I think is 2 gears manually, but in either gear it won't move. Thank you everyone who has helped me out before. I'm a newbie to 3 wheelers and don't know much about them.
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    it is a 5 speed tranny. 1 down and 4 up. but in order to get to second from 1st. you have to click up twice. my guess is the clutch may have been sitting long enough that they dried out and went bad. or you can adjust the clutch but im not sure on how to do that.
    Apr 2009
    hemet ca
    9
    I have a yamaha tri-moto 125cc. I needed a service manual or a repair manual can someone help me.
    TRI-MOTO KING
    Nov 2008
    Coon Rapids, MN
    956
    Hey david, here's a link to a web site that sells them.
    http://www.amazon.com/Yamaha-ATVs-Ow...8726608&sr=1-1
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
