84 YTM 200 Running Issue.
Hi, I'm new to the site and running into a few issues. First problem I have, I believe I have a 84' YTM 200. Freshly rebuilt motor, approximately 115'ish compression, adjusted valves accordingly. I can get it to run, but it either idles really high, and after a few seconds it wants to kill itself, pops back out of the intake. I can keep it running if I give it gas but seems boggy. Looked around and it seems to have the same carb as my 225DX, which I don't believe is correct. Can I run this carb or change the jets to work? Also wondering why it seems like it has decent throttle response in neutral if the engine RPMs are up a little, but when in gear, it bogs out? Any help or ideas would be appreciated.
I think the 225 carb is just about the same as the 200
//ArrowChat Integreation Code
