Results 1 to 14 of 14
Thread: 250r Kicker Gear Slipping
    Apr 2008
    Kalamazoo, Michigan
    814
    I know that the 250r kicker gear washers are no longer available. So how are we getting around this?
    Hmm :/
    Leave feedback for me here : [Please Don't start another thread again!]
    http://www.3wheelerworld.com/showthr...for-MagicJames
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Didn't the 89 go to the single sleeve versus the sleeve and 2 washers on the ATC's??
    Anyhow, what do those washers matter in terms of slipping?? If were talking 85/86 250R??
    Wanna buy a whole set I bought from a crate motor, shaft, gears and all ??
    Apr 2008
    Kalamazoo, Michigan
    814
    Yeah, i need the sleeve... or the washers. Either way.
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Apr 2008
    Kalamazoo, Michigan
    814
    Still can't figure this one out. Anyone have any suggestions?
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    ^ sure, 2 new gears and a shaft, or known low usage gears........
    I honestly can't see how just swapping the shaft fixes anything; I imagine it's merely the length of the old sleeve plus 2 washers and Honda decided thrust washers weren't needed there. That my guess.........
    Apr 2008
    Kalamazoo, Michigan
    814
    Maybe I'll have to make some new thrust washers, do they have any concavity or are they flat?
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    They are flat, which leads me to believe they don't play much of a roll in the gears catching and just seem to take up the space between the parts........
    Apr 2008
    Kalamazoo, Michigan
    814
    That's the part thats slipping. The gears are tight, just the spacers are missing to make it appropriately work.
    Gonna see if i can buy some regular washers, grade 8, drill them out to appropriate size then have them lapped to flatness?
    What do youthink?
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    I think thats a horrible idea............
    Thrust washers are just that, they take up lateral movement without damaging/scoring the adjacent part.
    McMaster Carr has every size/thickness washer known to man. I'm certain you can find something easier there to work with. And 20mm OEM is still available, make sure the collar hasn't shortened up, get out a micrometer and check the specs.
    Does that big gear come off towards those washers/spacers? or does it butt up against a shoulder on the kicker spindle? And come off the short or back side?
    I haven't had a LC R apart for awhile now.........
    Apr 2008
    Kalamazoo, Michigan
    814
    The washers are not available, if you can find them I'll take 10
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Hmmm, shows other parts discontinued but not the washers? You would still have to check the spacer length. How thick should they be, I can get you a link...... The OD by the case may have some room to grow, I'd need to see pics or confirm that. Sometimes you cannot get the EXACT Honda OEM OD with a given ID but the thickness is sold in thousandths..........
    Is the solid 87 and up TRX spacer DC'd too??
    Also, please answer my other question, does the big gear pull off the spindle with the spindle guts in place? or does it butt against a clip or a shoulder on the spindle shaft?
    Apr 2008
    Kalamazoo, Michigan
    814
    I dunno, i'm gonna have to go home and check, been at work and school all day.
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Apr 2008
    Kalamazoo, Michigan
    814
    yes the gear comes off towards the kick starter. It is not held on by anything.
    what are the overall Length specs of the spacer?
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    If the book doesn't show the spec, someone will have to measure one for you......
