Results 1 to 15 of 53
Thread: How to make my 1986 honda 200x faster
    Aug 2009
    Linden
    35
    I want to make my 200x faster without spending alot of money. i already have a DG exhaust, and the guy before me shaved down the fenders to help with speed. i know that changing the rear sprocket size will make it faster but i was wondering if i put a smaller 11 tooth sprocket on the front if it make it any faster or would it make it slower? im up for anything you think can help. just please give me some ideas!!
    1,736
    making the rear sprocket smaller is to making the front sprocket bigger. each tooth on the front will count as 2-3 teeth on the back i think. But this will simply just gear your bike up, giving it more gear not more power.
    with that DG pipe also take off the air box lid and jet it up for the extra air flow and that might make it a bit faster. but really if u want any big noticeable increases in speed (power, acceleration) its going to cost money.
    start with the simple stuff, higher compression piston, different cam, and you already have the pipe. that will get you started but there are countless things you can do to get more power, but they all come with a price.
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Shaving the fenders helps with speed? Heck, slap a NO FEAR sticker on it, that should give it a boost too.........just joking with you. I found a good way to make a machine faster is to be able to ride it faster....I'm 200lbs and the stock rear shock was much to soft for me, a good cheap fix is to install a 1983-85 200X shock spring onto your 86 shock. It's an exact fit and is much stiffer for aggressive riding. Also, any stock 200X I have ever rode had issues with serious fork dive. A set of progressive suspension fork springs and a bit thicker fork oil will solve the problem and your machine will handle much better. Both of these suspension mods will cost you around $85. It may not make the engine any more powerful or give you a faster top end, but for me, I can ride my X faster in many conditions. Instead of slowing down and rolling over doubles on the track, I can easily clear them....makes for a much faster lap time (if this is the kind of riding you do)
    Don't worry...just run watcha brung...
    Tape a wing to your helmet and add a wind scoop to the rearend, that'll do it
    Plenty of motor mods can be done if you get your wallet out. You wanna go fast straight line? or on the trails or track? It's all different situations.
    Sell it and buy a 350X. Problem solved.
    Xfile's Avatar
    Apr 2007
    Shiocton, Wisconsin
    700
    This also seems to work remarkably for many ATC riders
    Aug 2009
    Linden
    35
    well 350x guys i cant afford a 350x lol. im just fine with my 200x. its already as fast as a 350x with the mods done to it. and xfile: yes shaving the fenders gives you 2mph. thanks evryone for the replies
    BALLS TO THE WALL!! WHEN IN DOUBT GUN IT!
    Jerm1179's Avatar
    Jerm1179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Clevelandish, Ohio
    387
    how exactly does shaving the fenders give you 2 mph?...just curious....i bet if you completely remove the seat and fenders you could run with a 250r...
    ct
    1,396
    lol..took the words right out of my mouth !
    Quote Originally Posted by Jerm1179 View Post
    2MPH?? I'll take the whole seat and fenders off, maybe the headlight too, that ought to get me 5MPH
    Crest California
    3,014
    Just take all of the plastics off, and swap the tank for a lawnmower tank- you should be able to blow past a Tecate
    In all seriousness, if you want to make it faster, the least expensive way would probably be to drop in a smaller sprocket in the rear. I believe the stock is 40 tooth, so go with like a 36t. You will loose a bit of acceleration power, but gain a higher top speed.
    The more expensive mods would be to drop to a lower profile tire (like an 18" MAXXIS RAZOR) in the rear, higher flow air filter, then you can get into the expensive stuff like stroking out the engine, with a new cam, cranks, 218cc piston or so, but that all leads to a very high compression engine, which does not mean you can just kick it a couple times and go. Those high comp. pistons don't like to be kicked over fast, and will make sure you know. I know for fact. My stroker engine on my XR200R has a stripped kicker gear, so the kicker doesn't work, but it bumps right up.
    My stroked out XR200R will blow right past any stock XR200R, and will keep right up with a 250, but it had well over $1500 in work done on the engine.
    LED obsessed
    2015 Yamaha FJ-09
    Northern California
    90
    stroke it or go home
    Feb 2008
    Pennsylvania
    2,306
    Just what I was thinking
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    1,736
    cuttingn the fenders leads to the idea of making it aerodynamic. On a quad the front fenders can be like to giant para-shoots, but thats the theory of it. But to actually feel a difference i think would be a rare thing for a 200x. maybe a 100MPH banshee but thats it. its like a spoiler on a car, on slow stuff they do nothing
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    can someone explain how a 200X can be as fst as a 350X ? i love my 200X but come on...
