Results 1 to 7 of 7
Thread: Help with tires sizes
    mkramm is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    224
    okay what does each of the following number mean?
    25x10-12???
    is that tire diameter and rim width???
    I dont know. I will be looking for new tires for the big bear and I need to know if I can put 25x12's on the rims?
    Thanks
    May 2002
    Dublin, Georgia
    635
    dia x width x rim size
    The same as car truck tires.
    Jul 2003
    224
    thanks but that dont help...I dont know anything about truck tires either...im an electrical engineer, I know wiring, circuits & electricity
    May 2002
    Dublin, Georgia
    635
    again
    I put in the subject line above, sorry.
    tire diam x tread width x rim diam
    Jul 2003
    224
    okay so the tires on the big bear are 25x8-12 & 25x10-12 so 26x10-12 maxxis sur traks will fit? On both the front and the back??? If the guy still has them they are a great deal 70% tread for $60 for all 4.
    May 2002
    Dublin, Georgia
    635
    They will fit the rims
    The rim diameter is the same---12, so the tires will fit the rims. I do not know the clearances on the big bear, so I do not know if the tires will rub when turning or when the suspension compresses.
    May 2002
    Texas
    2,670
    What ejc042 posted in the subject line....
    Typical Size Meanings:
    22x10-12
    22 = Tire Diameter
    10 = Tire Width
    12 = Rim Diameter
    Hope that helps!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
