Results 1 to 15 of 16
Thread: how do i install the kickstarter?
    nova scotia
    4
    Cool how do i install the kickstarter?
    hello i have tryed over and over to put the kick starter back in but every time it does not return of sticks..it is on a 85 250sx. maybe my kicker is toast>? any help would be terrific
    Nov 2005
    New Jersey
    659
    got pictures, do you mean the kicker does not spring back, it stays down? Are you winding the spring correctly to put it under tension so it springs back? Have a manual by chance?
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    nova scotia
    4
    i have a manual i found online but it says to install it just how i removed it but it sprang out when removed... i guess i need to know how to wind it up...
    nova scotia
    4
    it sticks down , and also i tryed once and it only went down halfway and the stoped..thats when my case broke.. and then i gave up
    nova scotia
    4
    well thanks for nothing! i read in a clymer manual because the honda one you get on this site is garbage. the procedure. my starter had a bent spring which i straightend then you hook it in the crankcase in the inner hole on the right of the hole where the starter shaft goes in, also grease up that little washer because they fall into the bottom end. once your hooked have the kickstarter itself on the splines and wind the unit up clockwise, if it doesnt wind pull it out a bit and wind untill you feel the detendpass its lock, which is that metal bracket bolted to the case behind the gear...that is what holds the starter from un winding. so make sure it is bottomed out in its hole with that little washer on the inside and your good to re ass.
    south jersey
    49
    shoulda googled it brah
    1986 200x
    1980 cb750f
    Jerm1179's Avatar
    Jerm1179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Clevelandish, Ohio
    387
    your .....
    Quote Originally Posted by jomo View Post
    well thanks for nothing! i read in a clymer manual because the honda one you get on this site is garbage. .
    You're right. This site sucks. You should leave.
    here
    1,336
    ^ Yeah, frickin' 3-wheeler people anyhow! Maybe jomo, you'll have better luck downloading a grammar manual, those aren't provided on this site though.
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    This site is all newbies. The Honda manual on this site is crap.
    I doubt anyone on here uses it.
    /kick Jomo
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Someone let Honda know about Clymer manuals so they can stop using their "junk" ones and get some good information.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Springfield Mo
    3,309
    Guys you are being a little tough on this guy. I mean, he came in here asking questions about something he obvioulsy should have never taken on by himself. However, he did have enough knowledge to back the case bolts out. I wonder how many engineers worked on that Clymer manual? Do you think that they consulted Honda, or just put Honda's manual in their own words?
    This site is obviously crap. There isn't decades of information on here to help ungrateful newbs out!
    Jomo: Maybe while looking for help, you shouldn't bash the site you're inquiring from!!!
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Well, Thats a nice thing to say newbie.
    READ THE BOOK, READ THE BOOK.
    Further assistance: Line up all dots, make sure return spring is in place, use grease to hold a thrust washer on the back, if it has one.
    You have to tip the shaft on an angle to get it in it's bore and behind the plate it hides behind (hope you can find that by yourself)
    Tipping it allows you to get the spring ahead of that catch and then the shaft all the way in, then the kicker dots will be at 12:00. That thrust washer may now be in the gearbox if it's a 250SX or ES.
    Have a ball............
    I'll agree, this site is now filled with newbies and all the guys that knew there crap aren't here very often. I'm here but ignore many more posts now than I use to try and help with.......
    No one makes an attempt at downloading a book or didn't learn to read. But I be they can run there phone better than me
    Quote Originally Posted by Ironbnder View Post
    Your 100% right. Whats not in the Honda shop manual is in the Clymer. So, if people invest in a machine, they can spend 50$ on 2 manuals.........
    Or find them free.
    Jun 2009
    Tunkhannock,Pa
    904
    I think the Honda shop manuals are better laid out then the clymer manuals IMO. Plus its best to have some mechanical knowledge so you understand what they put right in front of you in the manual.
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
