Thread: Which Honda has a 17 inch wide front axle?
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    I am in the process of fixing up a strange 84 ATC200 that I bought over the weekend. It has what looks like an 200x style front end however its width is designed for the 25x12x9 inch tires that the big reds use. So its much wider than most that I have seen.
    The problem is that the axle is broken. The threaded end just cleanly broke off.
    So I am looking for an axle that is at least 17 inches wide. I bought one for a 200E but it is only 16 1/2 inches wide and when I put it into the front end, it isn't just wide enough to get the castle nut on the threaded side.
    Any suggestions?
    May 2008
    Juneau
    605
    250sx or early gen 250r front end? they use a 22x11x8 front tire but u could run a 25x12x9, check those
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    spokane, wa
    363
    I'm not sure. Does anyone know how wide those axles are? I can't find any info on the width of various Honda ATC axles.
    Baltimore, MD
    6,088
    Here's a novel idea, post a picture. Pictures help a ton. It may not be a stock honda front end, it may be aftermarket. I've had to have some custom front axles made before as well as the spacers.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
