Results 1 to 9 of 9
Thread: Lifan / Loncin 200cc Generator Output
    Jun 2009
    Leander TX
    2,217
    I have an OVH Loncin 163FML engine for my 200x. Anybody have any specs on the generator output capacity for these things?
    I will be mounting a pair of Hella 500s on a baja light bar and I'm toying with different wiring ideas. I'd like to run both 55w headlights at the same time along with an LED tail light and whip light.
    Also, it looks like I have 2 options for wiring. Either I can tap into the un rectified AC source or run the lights off the battery and use the DC side to power the lights and charge the battery.
    Any insights here?
    Feb 2009
    michigan
    2,387
    the lifan 200 i used went from 12v at idle to 30v at high rev
    1985 ATC 250R
    . Team Red Trike
    Jun 2009
    Leander TX
    2,217
    Interesting.
    I have the black version of your engine. I've been through your 185s upgrade thread a few times.
    I guess I'll wire up the lights and see what happens.
    I think I'll grab one of the little box voltage regulators and run the lights off the AC output before the Loncin regulator/rectifier. My theory is it will reduce the load on the Loncin piece that's primarily responsible for charging the battery right now.
    Jul 2008
    az
    16
    Check out this thread & my last post there. I'm guessing the lifan stator should be similar.
    http://www.3wheelerworld.com/showthr...-200x-amp-350x
    Jun 2009
    Leander TX
    2,217
    Great thread! Nice work on the stator re-wrap.
    I think the Loncin/Lifan motors use a multi-pole stator. I guess I could pull my cover and see what's in there.
    Jul 2008
    az
    16
    Mulit-pole should be easier.
    Jun 2009
    Leander TX
    2,217
    FYI - no problem keeping the battery charged with both 55W lights + tail on. Very cool!
    Beaver Falls, PA
    2,666
    Quote Originally Posted by harryredtrike View Post
    yeah, my Lifan 125 blew out a bulb or 2 before I started reading about rectifiers!
    Mar 2007
    Texas
    5,045
    ok look, the dual bigger lights use more than the engine was designed for, so I recommend takign your stator and getting it rewound by rickystators to be sure you have enough to supprot it. if not end result is a burned out lighting coil and your on the side of the road w/o lights at night.
    ________________
    https://www.mikesatvfix.com
