hi, i have a 84 honda atc 200s and when i rev the engine, the lights get to bright and burn out, what causes this? Thanks for any help.
Voltage regulater.
were is the voltage regulator on these machines, i looked at the wiring diagram for it and don't see it.
i was trying to look this info up in my clymers manual to post it and i can't seem to find info on where the heck it is either !
anybody know ???
john
i believe its on the back of the trike, under the seat behind the airbox. its a finned aluminum box. thats on the electric start models(200m). although after looking at partsfish, i can't seem to find one. so that trike may not have one and in that case you'd need to have the rear light functional so the voltage drops enough.
I just checked the wiring diagram in my Clymer's manual, and that trike does not have a voltage regulator.
Are you using the correct headlight bulb? If you are using a lower wattage bulb that could be your problem. The stock bulb is a 45W/45W
You could use a regulator off of a 350X.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
i am not sure the wattgae of the bulb, i just bought the headlight assembly new, it is aftermarket though, and not sure what wattage came with it.
The 200s's do not have a voltage regulator.
Check the bulb. I have sold many New Aftermarket Head light assemblies and they normally come with a 6volt bulb. A picture of the headlights I have sold is below.Originally Posted by atc 200s man
Howdy
You can get a voltage regulator from dennis kirk for $15.00. I got one fron Rickey Stator for the same $. It seems to help, it is easy to install also.
Sam from Florida
1985 BIGRED $ 200X
I bet it looks like this one. lolOriginally Posted by samster143
i bought a taillight for it, and now it works great.
Thanks for all the help,
Ryan
