First all, don't just tear the trike apart, do some detective work on it first. The cost is mainly your time. Get yourself a manual and read the trouble shooting section. How do you know the rings are trashed? it was smoking then it wasn't smoking, doesn't sound like rings to me. Have you done a compression test? If not, then don't even think of wasting money on a tear down yet! You got no clue what the problem is, yet you are ready to tear it apart?????? Have an herbal tea and mellow out. Do some yoga. LOL While you are drinking your herbal tea, read through your newly acquired shop manual. You could have some crappy old gas or who knows what, but if your valves are sticking the trike won't run. Do a tune up on your trike. Set the valve and ignition timing. change the oil and clean your filter screen. Adjust your clutch. Check your drive chain, lube it and make sure it's adjusted correctly. Lubricate your brake cables. Check your wheel bearings for excessive play or drag. But whatever you do, don't go tearing the engine apart needlessly. And if you do, you get what you deserve. Do you go to the Doctor and say, I have a headache, cut my skull open and check for tumors???????
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
