I bought a 84 200es with basically every part that moved needed replacing, But When i got it, it wouldnt engage in low, but high and reverse worked. I had someone rebuild the engine and they found washers that didnt belong and some missing in the sub Transmission. The 3 i need are the last washers on each shaft of the sub transmission,(towards the sub case not the engine) I was going to post this in classifieds since i need the washers if anyone has it, but its also technical, I called the local honda shop and they dont have it, does anyone know what other size washers would work or tips on where else to find them. I checked bikebandit.com and they have 2 of the 3, but the 3rd is out of stock. They have the 15mm, and the 17mm, for the first shaft and the last shaft but they do not have the middle 15mm washer for the center shaft. Its says its a 15mm also but its a different part number. Any tips or advice?
