Results 1 to 14 of 14
Thread: 350x tire size
    mrman550 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2003
    226
    350x tire size
    Right now i have 22-10-9 on the rear of my 85 350x whats the biggest i can go that will fit. Whats the best tire to get for mud snow and pavement?
    thanks
    I like the Kenda Klaws, they work in the dirt and sand, and will take on some mud. and they look good, I've never had a flat yet.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Roanoke, VA
    4,038
    Holeshot XCT's are the best tire for all of those conditions. My brother has them on his R and they hook up great in those conditions, and they wear very slowly so they will be great for pavement...
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Feb 2003
    226
    The tires i have on it now are 22-10-9 will a 22-12-9 fit on my rims?
    I am thinking of geting the bandit rears from pure sports are they any good? I will be getting my tecate runing this month so i am tearing down my 350x what kind of cluch kit should i get? Does a dg or cobra exaht make much difference. I am still looking for a good kickstarter for my 350x!!
    Roanoke, VA
    4,038
    Quote Originally Posted by mrman550
    Yup
    Jun 2003
    113
    Like Crazy said yes but the front tire may rub the forks if u go wider on the front..
    1986 200X
    1987 250SX
    1986 125M
    1987 125M
    83 110
    1978 Ford F350
    Get you a supertrap for your 350x recreation unlimited still has them, or if you like DG get the excellerater stage 3 sounds nice and does help out.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Roanoke, VA
    4,038
    Quote Originally Posted by 87 250SX
    He's talking about the rear tires...not the fronts
    Jun 2003
    113
    I no i was putting my 2 cents in.
    1986 200X
    1987 250SX
    1986 125M
    1987 125M
    83 110
    1978 Ford F350
    Feb 2003
    226
    so you are sure 22-12-9 will fit my on my rims that are 22-10-9 these are for the rear. and i wonthav any problems with the tire rubing it should just st a little higer right or just go with 2-10-9 to e safe?? what exactly does a aftermarket exahst do? what will it help?
    Roanoke, VA
    4,038
    You should be just fine....
    acourse it will fit 22x12x9 would fit fine as long as there 9 inch rims you can fit them. 22x12 is just the tire size the 9 is saying its made for 9 inch rims so as long as you have 9 inch rims your fine dude.
    Manny
    Jun 2003
    South of Rochester, NY
    3,470
    Isn't the second number the width? If the tires are 2 inches wider, will the beads set right on the rims?
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Fresno Ca
    2,695
    the first number is the height you can have any hight (to an extent) the second is the width. you can have a wider tire and a narrower rim. you can have a narrower tire also but it can be a pain to set the bead. and the 3rd number is the rim height and those HAVE to be the same
