I was crossing a stream an hit a sink hole. By instinct, I hit the gas and tried to bog through it....made it a few feet and then drowned it out. Water up to the handlebars. I think I sucked water in the air filter...not sure. I floated it to the other side and then drained the float bowl. Then I kicked it over about 5 times and it started. The problem was I couldn't push the throttle more than a little bit or it would backfire and shut off. If I got water in my motor, how much damage did I do???? Please help me on this one! Thanks.
