Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: cant find brakes for 250r
    suprise az
    43
    eh im not sure id have to puill the rubber off of it and its corroded where the pump moves up and down its all corroded il try to get some steel wool in there but it may be kinda hard
    ThReE WhEeLeRs ArE NoT ThE cAuSe Of PeOpLe GeTtInG KiLLed, NoT KnOwiNg How To coNtRol OnE is WhAt KiLLs.
    Legalize atc's!!
    suprise az
    43
    im pretty positive theres nothing wrong with the mater cylinder though because when i left the bleeder valve open and stepped on the brake lever it shot fluid out. what do you think about tthat?? still good you think or not sure cuz i have no idea im thinkin about buying a rebuild kit but dont want to if its not gonna do anything and thanks again holdontrike i think i may get that if thats my problem
    Legalize atc's!!
    near columbia sc
    36
    If it pumps fluid then its working, but I would want to clean it out at least because if any of the corroison breaks free it will end up in you rebuilt cal.
    You can heat up a straw from a can of carb cleaner or wd40 and wrap it in steel wool and it will make a steel wool q-tip that works great for small or hard to reach spots.
    83 Atc 200
    Saint Louis, MO
    22
    Quote Originally Posted by savage3006 View Post
    I agree with the cleaning before repairing, and the steel wool Q-tip idea is brilliant! I made a note of that for future reference cause I know that will come in handy;-)
    84 250R
    84 125M (2)
    suprise az
    43
    ok sweeeet yeah i was going to clean it anyways i hate knowing somethings dirty on my trike and putting it back together dirty irritates me ill try the steel wool q tip thing though thanks alot appreciated!!! so soak caliper in solvent, use wd-40 to clean master cyclinder and put it back together and see what happens?? if no luck try rebuild kit?? or what shall i do
    Legalize atc's!!
