i have looked everywhere went to used cycle shops looked on ebay anyone know where i can find a whole new/used set of rear brakes for and 84 250r? help would be awesome. Thanks!!!
 New to the board
						Arm chair racerNew to the board
						New to the board
						Here ya go says fits 84 250r
http://www.denniskirk.com/jsp/produc...Id=&mmyId=6694
83 Atc 200
no i mean like the caliper and the pump thank you though for the address of that though but the deal that the foot lever pushes on and all that i have pads and fluid resivoir and hoses. i have everything but i think the piston inside my caliper got moist inside and swelled up cuz i can get it to moved only with my hand i ripped it apart and cleaned in even smoothend it up with light sand paper and nothing i think i need a whole new caliper and piston and what not i cant find one anywhere i cleaned it all out and changed the fluid and blead the brakes and i even mashed on the lever with the bleader valve open and it shot fluid out its just not making my caliper clamp on that disk HELLPP MMEE!! . And does anyone know why i have oil in the little connecting peice that connects my carb to my air box the bottom of that little connecting peice always has oil on on the inside of it i clean it everytome but it always comes back?? boggling my mind
 New to the board
						New to the board
						I posted the answer to you air bvox on the other post about the carb. will look for a cal for ya.
83 Atc 200
 New to the board
						New to the board
						This is the kit you need but they dont have it right now
83 Atc 200
thanks alot!! i appreciate it the only ordeal is that i change one of the seals only because only one was bad do you think the rebuild kit would really help my sitiation cuz its so freakin hard to push that piston out with my fingers the only way we were able to get it out was using a c-clamp on it and driving it out i just dont wanna buy a new rebuild kit if it aint gonna work ya know??
x2... you also might want to get the rebuild kit for the master cylinder (the deal that the foot lever pushes on). If its your caliper, chances are the piston would cause the brakes to stick on. If it's the master cylinder, you might get one pump out of it then the master cylinder piston seizes. Try lightly sanding the m/c piston sides. These things don't like to work right if theres crap clogging it up. Use brake fluid to lube your rubber seals when you go to put it back together.
yeah i made sure i lubed them up with fluid before i put them back in and you think that could be the problem when i took off i did notice alot of corrosion like crap on the bottom of it thanks for the info
 New to the board
						New to the board
						when the seals go bad they cause the piston to get stuck. I have never seen the atc 250r cal in person but dont they have 2 o-rings on the piston? if so I really think that will fix your problem.
83 Atc 200
yes it has two seals one smaller one and a fatter one closest to the outside but ok cool thanks alot i appreciate it ill try it out and see how it goes
The manual says "if the piston sticks in the caliper cylinder, indicating severe wear or galling, the entire unit should be replaced", but it sounds like yours is moving (somewhat)...I've had luck with unfreezing several calipers just being patient with them and keep working them till they free up. Not sure if this place has the repair kit in stock, but your local motorcycle parts place should be able to get them. http://www.atcheaven.com/ATC250r.php...ws_ATC250R=232
I've seen the whole rear brake set up on eBay and recently, and I think they usually run in the $250's + used...but, I could mistaken.
84 250R
84 125M (2)
 New to the board
						New to the board
						no the caliper is good nothin in it its cleaned and good i guess it just needs a rebuilt kit but the master is what has all the corrosion under it under the rubber peice on the bottome of it. and sweet deal thanks holdontrike
ThReE WhEeLeRs ArE NoT ThE cAuSe Of PeOpLe GeTtInG KiLLed, NoT KnOwiNg How To coNtRol OnE is WhAt KiLLs.
Legalize atc's!!
Anytime Jimmyt...this looks like a better deal http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
84 250R
84 125M (2)
 New to the board
						New to the board
