Clutch problems
anyone have an idea why my clutch keeps slipping it is brand new and put on correctly i can ridefor a few hours then it starts getting worse ive taken it off once and put it back on it did the same thing it seems to be getting oil on it is this normal any ideas maybe to much oil in case
Im not sure, but some clutch fiber disks need to be soaked good in oil before they are assembled. Maybe the viscocity of the oil your using, or bad clutch springs.
what oil are you using?what kind of trike do you have?how much oil is in it now?did you soak the disk before putting all together?
1985 ATC 250R
Team Red Trike
//ArrowChat Integreation Code
