Results 1 to 13 of 13
Thread: need help 350x left casing
    ustin666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    moncton
    237
    350x left casing wont come of. I tried to remove my left cover for like 1 hour and it just wont come off the upper part came off a bit but the under side is like glued on or some ting. need help
    Rawlins350x's Avatar
    Rawlins350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2007
    Cairnbrook, Pa
    158
    More than likely there is a glob of JB weld or something on the case. Its common for people to rig them like that unless they get them tig welded. Clean the case off really good around and take a look.
    Dec 2009
    moncton
    237
    i don't think it been jb welded or tig welded its clean all the way around . the upper part is not stuck i can open it a bit and c in the engine but on the under side i cant open it
    PA
    3,515
    ..........you forgot a bolt.
    WWW.HREATV.COM
    Dec 2009
    moncton
    237
    no i triple checked it all the bolts are out
    Jun 2009
    Tunkhannock,Pa
    904
    maybe its seized on a dowel pin
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    scottp597's Avatar
    scottp597 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2009
    Lowell, IN
    153
    +1 seized on a dowel pin... maybe try pb blaster and a rubber mallet
    Beaver Falls, PA
    2,666
    Quote Originally Posted by SWIGIN View Post
    I thought I had all of them out, and I found one I missed... you may wanna check again.
    Aug 2005
    CT
    208
    Mine fought me a few weekends ago when i installed my Goki kit. I thought I had good cases but I found the JB Weld behind the sprocket and I had to work pretty hard to remove the cover without making the damage worse. Take a look behind the sprocket if you haven't yet.
    Dec 2009
    moncton
    237
    there is no jb weld i Araby check
    Oct 2009
    brazil indiana
    839
    there should be 12 bolts that you took out. if not that is the problem. the dowel pins are in the upper right and the middle/lower left. if it is stuck at the bottom i am not sure that the dowels are the problem but could be. the only other thing at the bottom is the gasket but if the top is loose the bottom should come off.
    TPC Trikes Are Awesome
    Oct 2009
    brazil indiana
    839
    OOPS, i am thinking the right side. sorry
    there should still be 12 bolts on the left side also but the dowels are at the top and at the bottom right.
    Dec 2009
    moncton
    237
    ya it probably the dowel pin because it on the bottom right
