part # ?
Can someone please tell me if these would be the same part? (1985 ATC 250r front section rear swingarm collars)( #8 on microfiche).
The 1st is the actual correct part # 52141-HA2-000. Are these the same:
52141-KS6-000.....(CR500) or 52141-KZ3-860....(CR250)?
The parts look the same from pics.... I already have new oem bearings to put in. The caps are a couple years old only- still good. The collars tho are scarred from the old bearings. I dont want to pay for a $50 or so rebuild kit or full price on new oem collars $30 or so + shipping. So I found these others at a great price but dont know if they work...........Also can grease fittings be put in on top without a problem on a stock swingarm (Where the needle bearings ride) Or would it protrude too far in? Would the grease go into the bearing?...I forgot the bearing has an outer casing so grease wouldnt probably go in.
//ArrowChat Integreation Code
