Noob question. How do you remove the front axle from an 84 200es?? Shop manual says to remove the nut. Than remove axle and 'collar'. The axle will not come out. Does it slide out or is the other side threaded in? It's stuck in there....![]()
1.5 1984 ATC 200es'
Got it..............
1.5 1984 ATC 200es'
Wanted to reply but
I never did an 84,
They say the 85 can weld itself in there somehow and I'm NOT looking forward to fighting with it.
How did you get yours out?
The shaft was corroded/stck to the outer brake drum/cover. I tried heat, denaturants amd a bfh. The bfh eventually won. I'm hoping I can salvage the shaft, it's pretty beat up.![]()
1.5 1984 ATC 200es'
Sorry for all the bad spelling on my last post, typing on my phone...
It slides in, no threads. It's a tight fit, and with the corrosion, it pretty much welded itself together. I'm going to use some neversieze on everything on final assembly.
By the looks of the shaft before I tried to remove it, I would say someone else tried to also as the end was mushroomed over and the nut was missing.
1.5 1984 ATC 200es'
i have a 1986 250 sx. trying to replace the bearings. can not get the $$#$$ axle to break loose. tried heat and lubes cheater bar bfh. noyhing is working. HELP PLEASE
