Results 1 to 3 of 3
Thread: My 2 200s's have different bolt patterns?
    booblinker's Avatar
    booblinker is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    WAshington, mi
    301
    Did someone change the hub it for a 200x hub or something? I want to swap tires onto my nicer one, but the rims are different size, and the bolt pattern is different. Both my 84s have a smaller bolt pattern than my buddies 85.
    -84 Honda ATC 200s("Rustored")
    -85 Honda 250SX
    -85 Honda 250ES
    -2017 CRf1000L (all ADVed out?
    Pacific NW
    4,255
    i think the 85 models wheels are different but the hubs may be the same.
    Hey wait, are you talking 200s or x?
    I'm confused.
    I got some x wheels for free and my s, sx and es hubs will not even fit inside the rims.
    Next I'll see if the 4 bolt 110 hubs fit the stud spacing for the x rims.
    Lately, however, if I know a little something and then ask questions, I wind up knowing LESS than I did before.
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Quote Originally Posted by drjoe171 View Post
    I'm confused.
    Why not just put 83-85 200X hubs on your S, or use 86-87/300-400ex hubs if you want to make it wider. The threaded portion of the s axle is smaller than the 200X axle, but the splines are the same size. All you need to do is mount the X hubs with a larger flat washer and the S bolt. I had 86X hubs on my 185S and it made a perfect stance (just a little wider)
    Don't worry...just run watcha brung...
