carb issue
so i just bought 2 new 1984 200x's, on one of the carbs wen the gas is on gas will drain out of one of the hoses? i cleaned it out real good so i just need a lil help.... thanks for lookin... does anyone knw wer to by new plastics for it???
sounds like your float may be stuck or the float bowl drain is still loosened from last years winterization.
Try tapping GENtly on the floatbowl and see if it stops and make sure the float drain screw is snug.
TG they are easy to get off and back on so worst case is a fast, cheap and easy rebuild.
//ArrowChat Integreation Code
