Thread: can anyone help me :)
    snohomish
    51
    hey where can i find the gears in which i shift? i got a clickin noise coming from it and my gears keep slipping and i wanna see if something is broke./ damaged
    1,736
    you would need to split the cases. which means complete engine disassembly. A good way to see if something is broken is drain the oil and look for little metal shavings or even chunks. plus it never hurts to change the oil anyhow.
    Crest California
    3,014
    Yep, change the oil. It NEVER hurts to do an oil change.
    Getting to the transmission means a complete splitting of the case, as I have done already.
    LED obsessed
    2015 Yamaha FJ-09
    Baltimore, MD
    6,088
    Have you tried adjusting your clutch? Do you have a shop manual to reference for how you do these types of things yet? If not, you really need to get one. And by the way, 25 + year old trikes, make noises. LOL
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Pacific NW
    4,255
    are you AND the trike a 110 atc?
    sometimes the hi lo range gets inbetween and essentially nowhere IF that model has the hi lo...praying for THE easiest answer for you.
    What year is it?
    does it shift ok but slip when you gas it?
    Pop out of gear?
    Can you tell us a little scenario story of what happens when you start it and run it?
    Thanks
