Results 1 to 15 of 15
Thread: Will a KLT 200 Engine fit in a atc 185 frame?
    Sep 2003
    somewhere
    25
    Can it be done with out welding?
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    i highly doubt it. an atc200 will bolt right in though. Kawi and honda don't usually mingle.
    85 200x - Torn apart
    Conversion
    As far as having enough room, it would probably fit, But....the mounts are completely different. You would have to cut the Honda engine mounts off, and weld on brackets for the KLT.
    Darrell
    83 185s *Now belongs to my nephew*
    83/84 200x
    85 Tri-Z
    85 350X
    85 Tri-Z Parts Donor
    88 Yamaha Moto-4
    Aug 2003
    Reno
    203
    Why?
    I have to ask, Why?
    Why would you want to do this?
    Earnest Hemingway:
    "Motor Racing, Mountain Climbing and Bull Fighting are the only true sports.
    All the rest are children's games played by adults."
    Sep 2003
    somewhere
    25
    Because I can get the frame $20 and I'd like to have a rear suspension. I'v got a KLT-200C2 with no rear suspension. It's striped down the the frame. I'm going to paint it today. Was just wondering if it would work. I'v seen a Harley Motorcycle with a Chevy 350 in it so I don't count out anything.
    Apr 2003
    Spanaway, WA
    1,244
    K5 do you think you could help me with wiring my 200 its an A but most likely the same wiring. just tell me what wires go where or show me in some pics? I wanna ride soo bad
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Sep 2003
    somewhere
    25
    Sure. I rewired my friends KLT 250. First I need to know how bad trailprotrailpro harness is jacked up. Does it need to be completely rewired or u just don't knowwhere some wires go? What's not hooked up? Let me know. U caught me at a bad time. I just striped mine to the bare frame. I found a wire harness and it's on it's way. Not sure when it will bw here. Mine is kinda rough but it was still doin' it's job.
    Apr 2003
    Spanaway, WA
    1,244
    um.. there isnt a wiring harness i have the cdi and all that except a battery would a regular 12 volt fit?
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    Sep 2003
    somewhere
    25
    Do u have any of the old harness? It's hard as hell to get everything right without a few key parts. Do u have the plug that goes in the CDI box? Do u have the plug that goes in the Regulator? Do u have the key switch, the off-on-off swith with starter pushbutton? If you don't, give me some time. I still don't know what wires do what on the Regulator. Once I get my wire harness I can do some tests and figure out what does what. My friends was pretty easy, I just needed to rewire the ignition switch, battery cables, solenoid, and coil. All the plugs where still there. Give me trailprotrailpro e-mail and I will sent some pics.
    Apr 2003
    Spanaway, WA
    1,244
    i have the plugs and the key switch but no key and the starter leads and ignition leads but i dont have the original throttle/switch assembly for the handle bar because the owner before last put a street bike throttle on. i also need to know if any shifter besides stock would fit because mines missing.
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    May 2002
    Dublin, Georgia
    635
    rear suspension
    I noticed in one of his posts he mentioned rear suspension. The atc 185 does not have rear suspension.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Sep 2003
    somewhere
    25
    It was modified. It was like the one on ebay.
    Apr 2003
    Spanaway, WA
    1,244
    can you pm me pics k5ride i dont have my own email
    PS i just noticed you joined on my 13th bday and you seem to be the only person that can help me with my trike, scary isn't it
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    Sep 2003
    somewhere
    25
    I would but I don't know how to post or pm pics. Happy B-Day! Mine is October 4, I'll be 21. I didn't have a trike or a 4-wheeler when I was trailprotrailpro age. All my freind and I had where Garden tractors. Mine had tractor grip tires so I went muddin' all the time. Now I'v got a 82 K5 Blazer that's lifted 6" with 35" tires. Me and that truck have been to heck and back. I'm gonna try and make my own wiring diagram. I get it to u as soon as I'm done. Later
    Apr 2003
    Spanaway, WA
    1,244
    thanks
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
