Results 1 to 10 of 10
Thread: How The Heck You Remove From Wheel From Atc ?
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    Can Someone Tell Me How To Remove From Wheel From '86 Atc;
    I Got A Flat,Need To remove It To Get It Fix. :oops:
    Thanks.
    Dec 2002
    SW Alabama
    764
    Which 86 ATC?
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Aug 2003
    290
    '86 atc 125
    '86 atc 125......don't know how to remove wheel to get flat fix
    thank you
    Jun 2003
    South of Rochester, NY
    3,471
    Double check the Schematics from say BikeBandit or PartsFish, but on my 350X, you loosen the four bolt clamp on one side, then screw the front axle out and the front wheel and hub drops out of the middle between the front forks.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    atc86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bangahore, mi
    306
    thats the easy part. if your rims are like my 86 get a sawzall and cut rubber off. then work on steel belts. seems like only a good "bead breaker" will work. they're about $400. james lucky's bead breaker was a joke. its still out in the field where it belongs.
    Aaron2003's Avatar
    Aaron2003 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2003
    293
    take it to a gas station and they will take it off for you for like $
    10.00
    Rittman, Ohio
    6,276
    Its a lot easier to just plug it, and you dont need to remove it at all.
    Jun 2003
    3,471
    Or try that SLIME tire sealer. I had some slow leaks on my LT-4WD and put that green SLIME stuff in them and blew them back up. Haven't had to add air since! I bought mine at Wal-Mart.
    Bruce
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    beads are not hard to break at all. all we have is just a big , like a 5lb or so and a wedge, it kinda looks like a splitting wedge but not as pointy. then you take that and go all the way around the tire and keep doing that untill to bead comes loose. then we have basically two pry bars that have a little hook or something in them to pull the tire off the rim. can get it done in about 5 min or less, and its free.
    Aug 2003
    290
    I Do want To Remove Wheel I Want To Paint Rims Too !!
    Thanks for all Your Post; I Went Up The Trails And came back With A Flat
    Don't Even Know It Happend,So I Needed Fix For Weekend,Also I Will Like To Paint Front Rim..So I Do need Wheel Out Anyway..I Could Kill Two Birds/One Stone :-D
