I have read that the banshee axle will work on the Z but is it the same length or longer and are there any problems if I use just the axle?
Thanks
Thanks
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
according to the swap list it is the same.dont see why you cant use just the axle
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
might want to check the top tier tri z build.he has a shee axle in there...
1985 Quad Killer
1985 Mini Raag
1990 Kawasaki 300sx
R.I.P
They are identical....
the Axle is Identical,, the sprocket hub is a great upgrade!,, over the steel incert stockers,,the break rotor hub& rotor is diffrent. all axle lock nuts will work... the rim hub spline is the same , but the hubs are diffrent Z-4/100. banshee 4/115.
So can I get an aftermarket axle like a G force for a banshee and it will bolt right on? Can you use all stock tri z parts or do you have to use the shee sprocket hub?
