Check and makre sure there is nothing between the needle and seat and the floats are set right. The fuel pump is often the issue for this stuff, they are not designed to widthstand the pumps pressure. The laws of gravity should apply here still.
PS
How does the trike run with those carbs on it? I'm thinking about upgrading mine to a 34mm mikuni, I've got a spare. I'm also thinking about trying an exhaust pipe off a late model RM125 dirtbike.
Update: My carb overflowed due to a fuel pump, its a 34mm
Reason: update
