Well, Is there any ways you can go thru deeper water without snorkels? My 83' ATC 185s can go thru water basically to the very bottom of the gastank (then its starts to sputter and die-if I come out of the water slightly as it just starts to sputter it will continue to run fine thru the water (and sputtering immediately stops) . It never sputters unless it gets to that water level- every time. Also, I dont have to over rev it to keep it runnin. (Now if i see i'm getting to that water level now,- I jump ship and keep it accelerated and walk it out). The water gets to the level of the ignition coil and cdi it seems which are side by side.(about 2 feet of water). If it ever does shut off, I just float it to shore,check the oil, its usually fine- and usually starts right back up immediately or within a minute or two... What I've had to do to get there: Ive used wheel packing grease on the cdi plug,- only cuz I forget to buy dielectric. Also on the sparkplug boot and at the ignition coil lead entry.I will eventually get some dielectric and use that instead. Also, I noticed with my carb vent hose, that when the hose was submerged- it would sputter and die. I now have a long vent hose running high up the main tube instead. Which now I can get to the water level I described above.(not sure why this is but it helped alot). Also, I put heat shrink on the harness-to-stator coil lead terminals (black/red wire). -The rubber sleeve on the terminals deteriorate and leak out electricity without it ..... Anyway, it seems that water depth can be improved.- .... I've seen some similar 200S atcs go thru just slightly deeper stock-but why dont mine do the same? My 81' ATC 185s would go thru about the same exact depth as my 83' does and that one had the early air intake under the seat?-Please dont preach to me about what I put my bikes thru
. I am an experienced atc owner/rider/shadetree mech.
.....anyone got any ideas?.
