Thread: 1985 350X Frame swap Questions
    High Desert,CA
    20
    Hey guys i am currently awaiting my frame from the powder coat shop. What i wanted to know is are there any differences in the 85 and 86 frames i have a complete 85 350X that i am swapping to the 86 frame. i have gusseted the new frame also. any info would be a great help
    ATC Addicted!!!
    Worcester, MA
    1,117
    The left side has a wrap added around the frame, where they usually crack. I think that is the only frame difference, the rest were black triples, clutch lever direction, fender color, etc
    Eastern Long Island
    1,688
    The 86 frame uses larger motor mount bolts than the 85. You'll need the 86 bolts and drill out your mounting plates.
    Lots O Trikes!!!!!
    2 10MM upper motor mounts.....
    junit's Avatar
    junit is offline At The Back Of The Pack Arm chair racerFirst time rider
    fremont ohio
    154
    the clutch cable is ran on the left side and not through the exhaust on an 86 frame
    High Desert,CA
    20
    good deal fellas, im out getting some stainless bolts today and pipe hunting
    ATC Addicted!!!
