Results 1 to 15 of 18
Thread: '86 250R Engine Hanger Bolt Hole Repair Question
    Toronto Canada
    697
    Hi guys,
    I'm working on getting a project 250r I picked up ridable, and before I attack this next problem I thought I'd better ask in case I'm missing something obvious...
    Here is a picture of my left-side engine hanger:
    The top bolt has sheared off - so I was thinking of simply drilling out the hole, and using a hardware store bolt with locknut.... am I missing something, or is that the easiest solution?
    I know most would say to probably helicoil, but if there's enough room for a locknut on the other side I think I'll just go that route for now!
    Tionesta, PA
    5,747
    you can do exactly what you are saying - be sure you have a very good drill bit to get that bolt drilled out. Otherwise you will break your drill bit in the bolt and then really be up crap creek!
    Toronto Canada
    697
    Thanks Tim!!
    110 atc's Avatar
    110 atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    green bay
    238
    I like to weld a nut or washer to the broken stud. Simply weld a nut to the bronken bolt and turn it out with a socket or vise grips. Works every time for me. Karl
    Toronto Canada
    697
    Quote Originally Posted by 110 atc View Post
    One of these days I'll buy one and learn how to weld! I've wanted to learn how for awhile now, I just need to get my ass in gear and do something about it!!
    Oct 2009
    FF, Man.
    774
    I would try an ez-out first
    My 3WW Feedback Thread:
    Salut Gilles
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    Use an ez-outs.
    There is all kinds of broken faster tools out there! Head to the local sears and check um out. Soak that broken bolt in a penitrating lube atleast over nite. Then drill a small hole about 1/2 in in then a slightly larger hole in3/8in in and a slightly larger hole about 1/4in in. This creates a more of a surface for the ez outs to grab since they are taped. Do not break the ezouts! you'll b fed in the A if you do. They are harded and require a carbide drill bit to drill out.
    Aug 2009
    Newfoundland, Canada
    915
    DO NOT use a "maybe-out" if that thing breaks off inside there, you only have worse problems. They are a B!t*H to drill through FYI
    Phoenix, AZ.
    6,719
    If it were me, I'd get a good quality left handed bit, heat up the frame and drill it using a low speed. You might get lucky and have it simply grab and back the thing right out. I always at least try to get the old bolt out before doing something drastic. I've gotten them out with easy outs but those things can and will break so you have to be careful. Heat is your friend.
    myles's Avatar
    myles is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    ontario
    162
    Xhumeka, you'll have to drill and tap it, you won't be able to fit a locknut on the other side, it would hit your head pipe.
    Toronto Canada
    697
    Quote Originally Posted by myles View Post
    Arg, you're right!!! That's exactly why I asked if I was "missing something obvious", and sure enough, I was!!!
    I've NEVER had luck with ez-outs, and I've broken a tiny drill bit inside a bolt once and it's something I NEVER want to do again. That's why I was intending to use a larger sized bit with less chance of snapping on me to drill it out.
    Oh well, helicoil time I guess!
    Toronto Canada
    697
    What if I were to use a flat-head bolt (like the one pictured below) with the head of the bolt between the exhaust header and the frame?
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I second what said about left handed drill bits. Sometimes it will unscrew the bolt out for you. A small set is a must have in your box.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Toronto Canada
    697
    Any suggestions on which type of drill bit to purchase? Last night I started to drill into the bolt, and after 20 mins of drilling with a fair amount of pressure applied I only have a small divet - I feel like the guy in Shawshank Redemption, this will take me YEARS!!!
    na
    5,702
    Cobalt bits will chew right through that. You can get them at any auto store.
    Make sure you are perfectly center, and use medium speed and keep the drill bit cool with penetrant.
    Do not use too much pressure on the drill bit. let it do the cutting for you.
    Proudly NOT a member of
    "Team on the Teat"
